Arduino Sensor RPM
  • Arduino Sensor RPM
    Here is the info on the RPM Sensor.
    Circuit - Signal is connected to digital pin
Name:	IMG_8052 (800x604).jpg
    Photo - Yes the bike wheel shaft does come out of the workshop wall.
    The resistors are on a small circuit board under the bracket.
    Sketch:
    /* RPM sensor using a Reflective Object Sensor OPB705WZ from OPEK Technology
    Using pulseIn() to measure a high pulse length in micro seconds
    Reflective surface is aluminium dsk with two black quadrants painted on
    Convert pulse time to RPM. Print out duration and RPM to serial monitor.
    int pin = 7;
    float RPM;
    unsigned long duration;
    void setup()
    Serial.begin(9600); // initialize serial communication at 9600 bits per second:
    pinMode(pin, INPUT);
    void loop()
    duration = pulseIn(pin, HIGH); // read HIGH, duration = 1/4 rotation
    if(duration > 5000) // duration of 5000 micro seconds limits speed to 3000 RPM. This stops erroneous data caused by transient spikes
    RPM = (15000000.0/duration); // (1000000uS * 1/4 * 60s) / duration = 15000000.0 / duration keeps calculation simple
    Serial.print(duration);
    Serial.print(" micro seconds ");
    Serial.print(RPM);
    Serial.println(" RPM");
    delay(10); // delay
    I hope this sketch is readable. Any suggestions welcome.
    Peter
    Hello Peter,
    i have build my RPM sensor, with a simple reed switch...
    when magnets of bicycle wheel fly by, the reed-switch closes..
    arduino can count this simple signal
    you need only an adjustable holder for the reed switch
    a reed switch is simplest way,
    i tried light detecting sensors too, but that was cumbersome in installation
    at this time i am not yet calculating the RPMs, but i count the magnets fly by,
    my cap pulser circuit discharges every x magnets went by
    FYI: my wheel is in range of 80-100 RPMs only, with 16 supernorth poles
