Hey everyone. First post here. Here a few months ago I was reading some online to see if there was any way to revive dead car batteries. After going through some threads with people claiming that they could fix a dead battery by pouring epsom salts in them, I stumbled across some of Bedini's work. Never heard of the guy or the concept of his motor, but I wanted to build one, so now...
I have it crudely built (pretty much a pile of wires sitting on my desk.) and got it to run last night about 2 am after my wire came in for the coils (150 feet of 20 and 22 AWG). As the power source I am using is a 12v power supply and the charging battery is a a small 12v battery that was in an electric gate.
While it runs, it seems to only be running around 250 RPM (If that, just my guess) and adjusting the potentiometer doesn't affect it any. When the power supply is on with nothing hooked to it, it sits around 13.6 volts. When I hook up the motor, it drops to 4.5v. Regardless of whether the rotor is spinning or not, the charging battery is around 2.2v. I was expecting 3k so RPM like i've seen in videos.
Thinking that maybe my power supply wasnt beefy enough, I went out and got my car jumper box and hooked it up. Voltage is around 12.6 volts at the power battery, but only like .4v is getting to the charging battery and it wont run. I was stumped, so I went and got the battery out of my truck to see what it would do. Same results as the jumper battery. When the car batteries are hooked up, it does have effect on the rotor (Pulls the rotor to the coil when the power is on), but it wont stay running.
I have the correct nv3055 transistor, the correct resistors and I think a 5k potentiometer (cant find the package).
As i said the coil is 150ft of 20 and 22 gauge and the core is R60 welding rod. Rotor is currently a electric cooling fan with the fan blades stationary and the frame spinning with ceramic magnets. Bearings are good and smooth in the fan. I plan on using a hard drive motor for the bearing but i haven't yet figured out how to extract it from the hard drive case.
If anyone has any info on what i may be doing wrong or have had similar issues, I would appreciate your help.
Thanks!
Thanks!
