Hi Julian,
Thanks for the update/info to solve the spike issue with the amp meters. Will implement those caps (at some point) in my device as well (currently blew up both my meters ).
I want to respond a bit more elaborate on your post, also on some previous ones, but still looking for the time to so, so for now I just share some of my initial ‘quick and dirty’ results.
COP Tests
Quick and dirty, because I wanted some ball park COP (Ah in versus Ah out), numbers and as long as they are far below 1 and/or, not a noteworthy change compared to a previous measurement I don’t care too much about the accuracy yet. So to explain what I mean with that/how I performed my measurement so far:
-Discharge 1Ah out of my output battery
-Next day charge with the Solid State Charger (SSC)
---Noting every 5 tot 10min the amp reading on the display of my power supply (see image below). (this measurement is probably a bit inaccurate, still have to start using my recording multimeter)
---Record the rising voltage in my output battery with the CBA
---Stop charging at 14.30V (since that is where my conventional charger charged to as well
-Wait for an hour (while recording with CBA)
-Then start at step 1 again Discharge 1Ah.
For the calculation of the Ah the PSU put in I took the amp reading @ +/-60% of the charge time, and multiplied that by the total time of the run; as mentioned this is very rough measurement.
Generally I would do one charge + discharge a day, except for the first tests (ID 230528 CM & 230530 CM), there I did two full charge/discharge runs in 1 day.
Test IDs 230528 CM / 230530 CM / 230532 CM / 230534 CM are done with IRF840.
Test IDs 230601 CM / 230603 CM / 230605 CM are done with STP20N95K5.
Rest of the settings can be found in the attachments.
Conclusions/follow up actions:
-For test ID 230528 I did not discharge 1Ah out of the output battery the previous day, but 4 days ago. The COP is therefore +/-10% higher then when I discharge the previous day. This I noticed as well with the Bedini SG, sometimes this difference could be even far more than 10%.
-With currently selected settings no significant difference between IRF840 and STP20N95K5.
-I was planning to continue testing with the STP12N120K5, then STW12N150K5, finally STW12N170K5, but reasoned that finding the right frequency might be more important to figure out first, so will probably focus on that as a next step.
Peak HV pulse of active devices
I re-did the measurements, this time a bit more in a reproducible manner so I could track the increase of peak voltage over a couple of minutes and comparing the different active devices. I included my measurements for the IRF840 / STP20N95K5 / STP12N120K5.
UPDATE 2023-06-05 -> Replaced attachment of active device measurements, contained a fault: 3rd test was not done with STP20N95K5 but with STP12N120K5.
Best regards,
Rodolphe
COP Tests
Best regards,
Rodolphe
