Hello Tom C,
What do you mean with wide open spot?
Never tried to measure the output with capacitor, but when using led's I see some points in the frequency range where they suddenly light very bright. When looking on the scope I see the output signal changing from sine wave to block wave (what offcourse is the reason for the sudden change in brightness), don't now if this are resonance points because normally the frequencies should be the harmonic, or there are different frequencies for the different batteries? At the moment I'm looking into this phenomenon to be sure I don't have a problem with the switching.
Do you have this sudden changes when you change the frequency over a wide range?
there definitely is a rate at which the cap charges faster and its not the wide open spot
but I really noticed improvent with the better 50/50 duty.
