When is the battery charged?
  • wild weasel
    hello there
    im having the same effect on my rig
    voltage accros the charging battery stays arround 12.0 to 12.2 volts going up and down
    im using a pair of 70AH batterys witch were in verry bad shape to start from so i assume its the batterys condition in my case
    starting voltage was 7.5 and 8.1 volts on these
    but after every cicle i see a small improvement
    im currently working on a new setup with 3 5 fillar coils in litz configuration based on a design by ron pugh
    now just a question for you guys
    what if i make the core in the coil larger? like 3 or 5 cm acros
    also the new coils are 0.5mm wires single for the driver coil and 3 starand litz for the charger coil
    anny comments welcome
  • Marine
    Hi Marine,
    First of all, No! the neon will never glow when the circuit is connected to the battery (unless the Impedance of the Battery is close(and as high as) to the impedance of the 'un-glowing' neon bulb)
    this happen only when a Capacitor is fully Charged, and typically when it crosses past the 90V Plus mark of the Neon glow-Discharge Voltage.)
    Tell me few things..
    1) what is your Battery AH capacity..?
    2) Your charging current is way low for the results that you are looking for.!
    Point no 2 can be solved by having a 6 filar coil to do the job for you with the Gen Mode described by JB in his DVD.
    Once you do this the Battery will retain (or even exceed) its original mark of Standing Voltage of 13.4 V
    let me know as you progress...
    Hi Faraday.
    I'm using 4.5ah SLA batteries.
    I've just made my coil a trifilar by just adding another main coil to my bifilar. I didn't un ravel it all, i just added it on to. That's ok right?
    My SG has been running for a couple of hours now with the new coil and i am now up to 13.10v going into the charge battery with the primary battery at 12.68v. RPM is around 129 and the circuit is drawing around 290ma from the primary battery.
  • Faraday88
    Hi Marine,
  • Bung-ee
    Yes ok but I'm not going to study your pictures ah ah !
    just put the list you have here...what you have.
    for the coil : how many strands do you have, what diameter, what length of wire ? (I have performance pbs with 100 ft for instance).
  • Marine
    Originally posted by Bung-ee View Post
    Hey Marine.
    850 turns - you do not know about your coil length ?
    + put your transistor models, resistor values, missing....
    + I see your coil is wound clockwise from bottom to up. that should be the counterclockwise (ie from a repulsion to a attraction mode)
    all the parts are in the first picture. I'm not sure i'm following you??
    My coil is the same as in the pic. I just did what Bedini has asked.
    Coil length is aprox 3.5 inches
  • Bung-ee
    Originally posted by Marine View Post
    It's this:
    18 magnets
    22" bike wheel
    850 turns bifilar coils
    [ATTACH=CONFIG]3202[/ATTACH][ATTACH=CONFIG]3203[/ATTACH]
    Hey Marine.
  • Marine
    oh. I call it the SG Matrix.
    Just put your figures after the "...............".
    21 magnets ..........
    26 inch bike wheel ...............
    free spin time above 8 minutes...............
    130 ft 9 filar coil 8 20 gauge 1 23 gauge wound in attraction mode...............
    R60 core 3/4 inch diameter...............
    mjl 21194 transistors ...............
    470 ohm base resistors...............
    12 ohm final resistor...............
    1n4007 diodes...............
    neon across the e/c : ............... (y/n)
    gap coil top / magnet : ............... ___ mm
    that is the checklist, each element I would say should match. If not, just put yours (for instance on my SG I have 22 magnets instead of 21).
    Then we are able to spot any anomaly.
    It's this:
    18 magnets
    22" bike wheel
ID:	46108Click image for larger version
  • Bung-ee
    21 magnets ...............
  • Marine
    Hi Marine,
    not being an expert what so ever, I think you need to check every item of your SG and compare to the expected specs.
    For instance, I had a 8 strands coil of #18, I was told it was explaining the 0.6 charging and other anomalies.
    would you put a list here, we could briefly check , unless you have already done so.
    sorry i'm not following you??
  • Bung-ee
    Hi Marine,
  • axxelxavier
    Originally posted by aln View Post
    axel,
    Alum batteries are very durable. Discharge them to 7 volts if you want. I charge them up to 15 still and they come down to 12. If you discharge them that low, start charging again when done discharging soon and you will see it takes a while to fill them up. They hold a voltage well in the 7-10 volt range (meaning they don't give up like H2SO4 batteries). Aln
    thank you for responding. I usually charge alum batt to 15 volts, and I always wondered if it is not to much...
  • Marine
    Originally posted by Brodie Gwilliam View Post
    charging battery negative straight to primary battery negative(instead of positive), try to make sure your primary is at same or less voltage than your charging battery
    Tried that. Seems to make no difference at all....
  • Brodie Gwilliam
  • Marine
    neg to neg will help you get there, but ive found once a battery tops out and stops climbing you gotta put a small load on it for a couple hours (i used a 1amp bulb)and then put it back on the wheel and each charge cycle you should get a little higher in voltage
    Thanks for the tip about putting it on a load now and then.
    What did you mean by "neg to neg" though?
  • BobZilla
    Yeah i see my neon bulb light up sometimes when i disconnect the charge battery briefly but that doesn't mean i get 100v going to my charge battery
    Yea it does.
    When your charge battery is connected it goes there, when disconnected the neon absorbs it to protect your transistor.
    Brodie is right, just keep cycling your battery and see if it improves. Get the best charge on it you can and drain it off, repeat.
