This thread is for the discussion of Gravitational Potential Energy - one of my favorite topics and just about the easiest to prove that gravity is dynamic and is a contributing force that supplies its potential to do work.
The example is very simple.
If we have a ball of clay that does not bounce at all, it is 0% efficient in bouncing and is 100% efficient in performing impact work.
If the clay ball is 2.5 kg and we lift it to 1 meter on from the surface of the Earth, we can figure the following:
Work or W required to lift this ball to 1 meter is W = Fd, W = Force x distance, W = (mass x gravity) x distance, W = 2.5kg X 9.81 X 1 = 24.525 joules of work. That is 24.525 real units of work, dissipated energy, or real entropy.
The Potential Energy or PE available to that object at 1 meter from Gravitational Potential Energy is PE = mgh, PE = mass x gravity x height, PE = 2.5kg x 9.81 x 1 = 24.525 joules of Potential Energy - not stored in the object since it is myth that we store any potential in an object. What we got out of the work we already expended to lift the ball was the lift of the ball itself - it is all used up and there is nothing left to store even if we wanted to.
When the ball of clay is released from 1 meter and hits the ground with a thud, the object falls with the flow of the downward moving dynamic Gravitational Potential Energy. That potential is not really performing work since the ball is not resisting it. There may be minor insignificant resistances from the air - almost nothing for a ball at 1 meter. When the ball hits the ground, the ball then resists movement and then the Potential Energy available from gravity in the amount predicted by the PE = mgh equation shows us that 24.525 joules of real work, dissipated energy or real entropy were realized in the form of heat, etc...
When we lifted the object, we contributed 24.525 units of entropy. When the object hit the ground an ADDITIONAL 24.525 units of entropy were contributed free from Gravitational Potential Energy. 24.525 + 24.525 = 49.05 joules of total work, dissipated energy or entropy were performed that are mathematically calculable.
If we take 49.05 total work and divide it by what we had to pay for, 24.525, that equals 2 or a COP of 2.0. That is a 200% net gain in real work energy compared to what we put in.
This is an indisputable universal principle that applies to every single open dissipative system.
We know for a fact that the lifting work of 24.525 joules is entropy and the thud on the ground is 24.525 joules that is also real entropy that happened with time moving forward, so there is no negative work being done here. Both are heat producing events that contribute to the entropy of the universe.
Since 49.05 joules is more than we contributed, it is only common sense that the other 24.525 joules of Potential Energy came from external forces proving beyond a shadow of a doubt that this is a system that is NOT isolated from external forces and 3rd grade elementary school math proves this. Not only does it mean that conventional closed system thermodynamics do not apply to this system, it proves that gravity not only can be but is an absolute source of Potential Energy that can do work.
This COP 2.0 principle is universal in open systems at a MINIMUM! That is if there is one cycle and one cycle only and the system does not regauge itself or create a new dipole through its dissipative processes.
Peter Lindemann has taught this for years in regards to electric motors. For every one unit of work you put in, you are getting a freebie and when you sum them, you get twice as much as what you put in.
Paul Babcock who gave the Magnetic Energy Secrets presentation says the same thing and also proves this with real experiments. He says nature gives you a freebie for each unit you put in meaning there really is twice as much work being done compared to what we put in. And his inductor arc experiment is demonstrating in front of everyone's eyes a COP of 2.0.
When conventional physics claims you "get out what you put in" - that is a psychotic delusion out of touch with reality. It is a brainwashing attempt to prevent people from seeing the truth shown in the 3rd grade math examples above.
They say you put in 1 unit and you get 1 unit out. Ummm, what you get out of it IS THE LIFT OF THE OBJECT IN AND OF ITSELF. They can't discount the fact that what we put in IS entropic work and when the ball is lifted to 1 meter, what we got out of it was the lift. At the peak, 100% of every bit of energy we used up is gone never to be seen again. It was 100% dissipated back to the environment. There is no conservation.
What we did was expend 24.525 joules of real work and this established a dipole of 1 meter. At this point, we ALREADY got out of it what we put in. Anything after this point is IN ADDITION TO what already happened.
When the object is dropped, an ADDITIONAL 24.525 joules of work will occur on impact for a total that is 200% of our input.
Therefore, for every 1 we put in + 1 free from nature = 2. Therefore, 1 + 1 = 2.
Conventional physics says we put in 1 + we get out 1 = 1. Therefore, they literally are calming 1 + 1 = 1. That is why they're delusional.
What we are able to prove with 7 year old children's math is that gravity absolutely is Potential Energy that can do work.
Being that it is a fact, that means that gravity must be active and not some passive or static phenomena. If it was static, it could not contribute anything and if it was static, then every bit of potential that turned into work must have come from us, must be stored in the object when lifted as it would be cut off to any external forces and conventional thermodynamics would apply since it would be an isolated system.
But all that falls apart the moment we mathematically show very simply that twice as much work in measurable joules of entropy have happened and half did not come from us.
