Originally posted by Faraday88
Currently, the best way to characterize the aether is as a supersolid and the best way to describe the aether is in terms of its displacement by matter.
"Doth not this aethereal medium in passing out of water, glass, crystal, and other compact and dense bodies in empty spaces, grow denser and denser by degrees, and by that means refract the rays of light not in a point, but by bending them gradually in curve lines? ...Is not this medium much rarer within the dense bodies of the Sun, stars, planets and comets, than in the empty celestial space between them? And in passing from them to great distances, doth it not grow denser and denser perpetually, and thereby cause the gravity of those great bodies towards one another, and of their parts towards the bodies; every body endeavouring to go from the denser parts of the medium towards the rarer?" - Newton
Newton is referring to the state of displacement of the aether.
The aether does not grow denser and denser. However, Newton is correct, displaced aether pushing back and exerting inward pressure toward matter is gravity.
""In several parts of this treatise an attempt has been made to explain electromagnetic phenomena by means of mechanical action transmitted from one body to another by means of a medium occupying the space between them. The undulatory theory of light also assumes the existence of a medium. We have now to shew that the properties of the electromagnetic medium are identical with those of the luminiferous medium." - Maxwell
Maxwell's displacement current is a physical displacement of the aether.
'Ether and the Theory of Relativity by Albert Einstein'
Einstein: "Ether and Relativity"
"space without ether is unthinkable"
"the state of the [ether] is at every place determined by connections with the matter and the state of the ether in neighbouring places"
The state of the aether at every place determined by connections with the matter and the state of the aether in neighboring places is the state of displacement of the aether.
'Interpretation of quantum mechanics by the double solution theory - Louis de BROGLIE'
“When in 1923-1924 I had my first ideas about Wave Mechanics I was looking for a truly concrete physical image, valid for all particles, of the wave and particle coexistence discovered by Albert Einstein in his "Theory of light quanta". I had no doubt whatsoever about the physical reality of waves and particles.”
“any particle, even isolated, has to be imagined as in continuous “energetic contact” with a hidden medium”
The hidden medium of de Broglie wave mechanics is the aether. The “energetic contact” is the state of displacement of the aether.
A moving particle has an associated aether displacement wave. In a double slit experiment the particle travels through a single slit and the associated wave in the aether through both.
Aether has mass. Aether physically occupies three dimensional space. Aether is physically displaced by matter. Displaced aether pushes back and exerts inward pressure toward matter.
Displaced aether pushing back and exerting inward pressure toward matter is gravity.
short form,
