Big-Bang falacies and the Occult Aetheric Physics reality.
  • The Universe, or our local Universe, is a larger version of one of these.
    Dark energy is aether emitted into the Universal jet.
    It's not the Big Bang; it's the Big Ongoing.
    • [1212.4176] Empty Black Holes, Firewalls, and the Origin of Bekenstein-Hawking Entropy
      "But why an incompressible fluid? The reason comes from an attempt to solve the (old) cosmological constant problem, which is arguably the most puzzling aspect of coupling gravity to relativistic quantum mechanics [13]. Given that the natural expectation value for the vacuum of the standard model of particle physics is ∼ 60 orders of magnitude heavier than the gravitational measurements of vacuum density, it is reasonable to entertain an alternative theory of gravity where the standard model vacuum decouples from gravity. Such a theory could be realized by coupling gravity to the traceless part of the quantum mechanical energy-momentum tensor. However, the consistency/covariance of gravitational field equations then requires introducing an auxiliary fluid, the so-called gravitational aether [14]. The simplest model for gravitational aether is an incompressible fluid (with vanishing energy density, but non-vanishing pressure), which is currently consistent with all cosmological, astrophysical, and precision tests of gravity [15, 16]:
      __3__
      32πGN Gμν = Tμν − Tα gμν + Tμν ,
      Tμν = p (uμ uν + gμν ), T μν;ν = 0,
      where GN is Newton’s constant, Tμν is the matter energy momentum tensor and Tμν is the incompressible gravitational aether fluid. In vacuum, the theory reduces to GR coupled to an incompressible fluid."
      [1208.3458] An Extended Dynamical Equation of Motion, Phase Dependency and Inertial Backreaction
      "We hypothesize that space itself resists such surges according to a kind of induction law (related to inertia); additionally, we provide further evidence of the “fluidic” nature of space itself."
      [1202.4611] Fluidic Electrodynamics: On parallels between electromagnetic and fluidic inertia
      "It is shown that the force exerted on a particle by an ideal fluid produces two effects: i) resistance to acceleration and, ii) an increase of mass with velocity. ... The interaction between the particle and the entrained space flow gives rise to the observed properties of inertia and the relativistic increase of mass. ... Accordingly, in this framework the non resistance of a particle in uniform motion through an ideal fluid (D’Alembert’s paradox) corresponds to Newton’s first law. The law of inertia suggests that the physical vacuum can be modeled as an ideal fluid, agreeing with the space-time ideal fluid approach from general relativity."
      • 'Toward a real synthesis of quantum and relativity theories: experimental evidence for absolute simultaneity'
        [1301.4253] Toward a real synthesis of quantum and relativity theories: experimental evidence for absolute simultaneity
        "Abstract. We have demonstrated spatially-discontinuous quantum jumps of electrons at a distance as long as about 1cm. The effect occurs in a modified integer quantum Hall system consisted of a great number of extended Laughlin-Halperin-type states. Our observations directly contradict the no-aether Einstein’s interpretation of special relativity together with the Minkowski’s model of spacetime. However they are consistent with the aether-related Lorentz-Poincare’s interpretation that allows absolute simultaneity. We thus strongly challenge the fundamental status of Lorentz invariance and hence break the basic argument against de Broglie-Bohm realistic quantum theory. We argue that both de Broglie-Bohm and Lorentz-Poincare theories are capable of providing a real synthesis of quantum and relativity theories. This synthesis is of such kind that quantum theory appears the most fundamental physical theory for which relativity is only a limiting case. In accordance with this hierarchy, quantum theory naturally resolves the problem of aether in Lorentz-Poincare’s relativity. The role of aether could be played by a deeper Bohm-type undivided quantum pre-space, the relevance of which at any lengthscale directly follows from our observations."
        "The point is we break the basic argument against pilot-wave theory, that is, the lack of Lorentz invariance. We have thus got two quantum theories, standard QM and the pilot-wave theory, and both are equally successful in prediction of experimental observations. However, their principle difference is that the former rests on mysticism and indeterminism while the latter rests on realism and determinism which is the basis of all current physical theories. As a result, the former encounters serious conceptual problems and can hardly be unified with relativity theory. Conversely, the latter naturally avoids conceptual problems and can easily be unified with relativity or, more precisely, with the Lorentz-Poincare’s version of this theory. In this situation, the choice in favour of one of these theories seems self-evident though it clearly will take some courage to overcome the existing prejudices about quantum theory."
        What waves in a double slit experiment is the aether.
