Walter Russell Tech
  • Walter Russell Tech
    Hello everyone,
    I just wanted to say hello and get a thread started about Walter Russell's work. I really enjoy it and I seem to find proof of his concepts more and more with new tech that comes out. For example: e-Cat and inert gas/plasma systems(Rohner)
    I am gathering as much info as I can on his experiments and ideas but I would love to know if anyone has access to the documents that John Bedini mentions in the "energy from vacuum" video. The copies that were given by Lao. Thanks and much love!!
    http://lightcoalition.org/ my site for Walter Russell info...wip
    I am just finishing up "The Secret of Light", and I also have "The Universal One" standing by. Very interesting stuff. When I heard J.B. mention that John Cejka was a big fan of Russell, I thought I should look into what he had to say. The diagrams from his writings that were shown briefly on the EFTV DVD about transmutation of elements can be found in both books, but there are more of them in "The Universal One". I bought both books on Amazon. Fascinating. There is a lot to assimilate here.
    -Woody
      Yes... I find this work to be very fulfilling. It took me a while to get used to the vocab but once I did it was amazing. I have read most of their(Walter and Lao) books and study course. I go back and look up things and learn new things each time. Atomic Suicide is my favorite but then A New Concept of the Universe is also great. The earlier books help for looking things up IMO but it is in more layman's terms with the newer ones I mentioned.
      I have lots of images/docs about transmutation from WR and some others who have tried it, but just wanted to see if J.B. happened to have some notes or extra things most don't have.
        Any that you would be willing to share?
          Sure. I just uploaded a couple to the Documents section of my site. (listed in my sig)
          Found them on the web in the past.
            Hello everyone,
            Hi there,
            I agree Russell had some unique insights into energy protocols. You might like to follow this link to an interesting experiment regarding Russell and Transmutation - http://www.scene.org/~esa/merlib/russell.pdf
            Also, there is a very good video from the "Energy form the vacuum" series, No 18, in which John Bedini briefly discusses Russell and Transmutation. Lots of experimental opportunities there!
            Good luck and regards
              Originally posted by Dwane Dibley View Post
              Hi there,
              Thx Dwane... yes that is the experiment I would like to replicate. I am in the process of working out how I will do it. I also have seen that video which spawned this thread of getting copies of what John said he had from John Cejka. Thx again.
                Hi there cplouffe,
                The reason that I gave you two references was to indicate that from my reading of Russell's hypotheses, that there is more than one method of his transmutation. That is, John B is demonstrating a "take no prisoners" approach, using Hydrocloric acid, which Russell also is suggesting, to eliminate those elements not required. I do not personally see this as transmutation; transmutation implies a migration through atomic structures. The Westinghouse experiment is a more elegant solution and concurs with Russell's philosophy of a migration of elements from one position on his period table to that of another element. Therefore, indicating a constant transmutation process is possible, through the influence of the magnetic vorteces that make up his paradigm for energy. Hence, one method is to set up magnetic fields and using controlled points along his periodic table, the neutral or noble gases as the source (fulcrum) of transmutation for the following or preceding isotopes or elements in that sector, one is able to transmute to any element that you want. I have no doubt that this is possible, just a lot of experimental work required. Be cautious of the "Midas" touch though. Could be you might devalue gold to that of lead!!
                Have fun with it, regards
                Dwane
                  I would agree that there is more than 1 method but based on the same principle of moving up and down the octave wave or pressure conditions. Yes his Westinghouse experiment is very elegant and it shows just how easy the concept can be once you "know" how to change pressures and electrical potential. I think I will start with nitrogen or another element that is much more readily available than an inert gas. Thx!
