Greetings Friends,
I have a new board to share with the group.
This is as close of a replication of FIG.1 in Mr. Bedini’s Patent #US7990110 as can be obtained with automated switching. Mr. Bedini’s diagram is meant to explain the process of obtaining a spike and mechanical switching is represented. I have replaced the mechanical switch with a FET and a micro controller but no other additions have been made.
Here is a picture of the board:
The coil is fed at the “top” end from the primary pos.
The “bottom” end of the coil connects to the drain of the FET, the source of the FET connects back to the primary neg. This is our switching point and it creates our closed loop.
Extended from the drain we have the anode of the diode connected and the cathode connects to the charge Pos. This is where the spike appears and is our open path.
The charge neg is connected to the Primary Pos.
I have a 75V Neon across the charge POS/NEG which is not necessary for the circuit. It is only there as protection and as an indicator.
The Gate of the FET connects to the microcontrollers logic signal (5v 20ma) through a 150 Ohm resistor. There is also a 10k Ohm resistor from gate to source.
The switching is then controlled by programming the microcontroller with ON/OFF periods of the logic signal. The power source for the microcontroller is external to the circuit; I use USB battery phone charger to power the board currently. The estimated draw for the triggering is about 40ma; 20ma out for the signal and 20ma is used up by the chips onboard.
This circuit is exhibiting some very interesting properties which I have not seen on other builds. For example it self adjusts to the load!
It feeds the charge battery at precisely the correct pace to achieve a perfect charge, simultaneously self adjusting the draw from the Primary.
As usual I have a video for those who wish to see more:
https://files.secureserver.net/0s3zGg7AxRcbAS
