Hi Folks,
Here is my problem. I need a real solution.
I want to power this device potentially 8 hours of the day
Two of these devices comfortable heats an 1100 sq ft they are safe and have auto shut off.
I bought solar panels and deep cycle batteries only to find out that running this simple one little device isn't even possible.
Is there a solution? Average person doesn't have a 4-6 kw solar solution and I am very disappointed in the solar panel industry for running ahead without even being able to power a simple space heater 7x24
Someone selling a bedini motor says even a bedini power motor isn't practical to power a battery bank instead of solar panels.
How would you power this device ?
If humanity cannot solve this I think its very disappointing
My UNIT TEST
I unit tested the setup outlined below
o the heater was running
o within 1 minute PROSine inverter beeped LOW BATTERY POWER and 25vDC started to falling to 19vDC
o connected Klein CL2100 for DC amps on positive battery bank cable it showed 078.5 not sure what that meant
feedback appreciated
One of my issues is calculating how big a battery bank I need to sustain this simple little ceramic heater with a strong enough charge to run it hour to hour or even every other hour would work too
- cheers
-- signature
24vDC offgrid system
Array 1 - LG 300watt panel 39v 9amp times 3 (one array is 3 panels) feeds Xantrex C40 charging at 26vDC
Array 2 - LG 300watt panel 39v 9amp times 3 (one array is 3 panels) feeds Xantrex C40 charging at 26vDC
So Panel setup is 2 arrays composed of 3 300watt panels each each feeding its own separate C40 charge controller jumpered at 24vDC
Battery Bank currently 4 deep cycle 12vDC batteries wired in paralell connected serial (24vDC bank) feeds AC Inverter Xantrex 1800watt PROSine jumpered at 24vDC
My UNIT TEST
- cheers
-- signature
