Dr. Douglas Lindstrom spoke on the ECE Unified Field Theory - and amazingly, much was quite understandable to the layman. He did cover some mathematics but also covered many concepts involving overunity processes in cold fusion and even parametric oscillators, which are going to become more and more popular in this field. There are references to some of the parametric work and some has been replicated and verified. His presentation will also include a PDF of the PowerPoint with all the notes. Dr. Lindstrom works with Dr. Myron Evans - Tom Bearden considers him the most important physicist alive.
Al Throckmorton's presentation was very inspirational. This was a very rare appearance. Half of his presentation was really his story about who is he and much of his life experience, which was filled with priceless nuggets of wisdom. He had his special water gas pump, which is detonated with the plasma ignition circuit. We couldn't pump water with it since we were in doors, but he did fill up the chamber and detonated the gas and the pressure gauge was over 200 psi, which is way more than enough to pump a very substantial amount of water. We'll be including some diagrams and schematics for the pump so others see exactly what it is. The first application will be for small village use in Africa to pump water over long distances to improve the quality of their lives, which much of it is spent simply carrying water miles and miles from a remove water well.
Aaron Murakami (I) presented on the plasma ignition. Last year I spoke about the theory, operation, etc... with some demos. This year's talk was to specifically show how I overcame the issue of wasted spark ignition systems and how to put the plasma ignition on these ignitions, which are so common these days.
Paul Babcock presented on Ethanol, debunked a lot of the anti-ethanol propaganda that is so popular and showed some of the designs that he and his brother have developed, which make small scale ethanol production a breeze. Ethanol is freedom and you'll really learn why in this presentation. Ethanol is as good as cash or even better if you have a smart game plan and in these financially troublesome times, this information is priceless.
John Bedini showed his self-running motor - it was the first thing he showed me 16 years ago when we first met. It is really 3 machines in one and operates on one set of old 25+ year D cell alkaline batteries that are corroded, the springs in the battery holder are rusted out and the batteries are just taped in there. He spins the rotor and it starts off slow, turns a rotor with a propeller and blinks LEDs to show what phase the motor is in. By the end of John's talk, it is about 25-50% faster than it was in the beginning - not because it took that long to get to full speed but because it recharged its own running battery over the course of the presentation.
Graham Gunderson showed a simple transformer setup and demonstrated that it not only makes up its own losses, but actually produces a bit more. The overunity is small, but it is something he wanted to share with everyone because if you can't get to unity, you're not going to get to overunity. Since there is an obvious lack of enough replications of several overunity devices that many people are attempting, taking baby steps with this very simple transformer concept is absolutely necessary. Any builder with basic technical skills can make this transformer and by following Graham's instructions and references, they can achieve the same results.
William Lyne gave a fascinating comparison between some of the propulsion ideas of Tesla and J.J. Thomson. Eric Dollard was the one that actually suggested this topic since there are many gems inside of Occult Ether Physics by William Lyne. J.J. Thomson is one of the most important scientists to understanding not just the electrical sciences, but the real physics of the aether.
Paul Babcock's second presentation was on Magnetic Energy Secrets part 3 where he makes it VERY simple to understand what is necessary to create an overunity motor. He breaks it down to 3 very simple principles that almost anyone can understand. Paul covers multiple machines that have overunity results and shows how they are all adhering to these concepts. Back EMF is the bane of overunity and he shares the principles necessary to create a motor that does not generate - meaning there is simply no back emf!
Jim Murray presentation is crucial to the successful replication of his Dynaflux Alternator. Many who have tried to replicate it have failed. He shared the most important secret to understand to making it work as well as disclosing for the first time ever several pieces of information that were never disclosed in the patent. The patent has been expired for a long time now so it is public domain and he wants everyone to be able to understand what it is really about. The COP is over 2.5 on his laboratory bench model, which means it produces over 250% more electricity than it takes to run it.
Jeane Manning moderated this year's Panel Discussion, which included Eric Dollard, Al Throckmorton, Graham Gunderson, myself (Aaron), Jim Murray, Paul Babcock, William Lyne and Douglas Lindstrom. We discuss some common threads between different valid overunity technologies, the creative process and its importance, Graham and Eric discuss Tesla's patent which utilizes Cosmic Rays to charge capacitors to power loads and Eric gives some very clear specifics on this as he has replicated this in the past. There are multiple discussions about splitting water without electrolysis using electrostatics to rip the water apart without running current through it. Al Throckmorton's water fuel cell for the pump that he demonstrated does not use electrolysis to split the water, it is a water capacitor and it works incredibly well. I share one patent on this kind of process that I tried to duplicate in the past and Eric Dollard discusses his friend's work in this area who successfully mastered the electrostatic separation of water. Before we started the Panel Discussion, we gave recognition to the four Electrical Engineering students and two musicians who won the contests to have their conference and lodging costs covered by an Anonymous Donor.
Veljko Milkovic was not at the conference but his team was kind enough to provide us with a video compilation of quite a bit of his work. We played some of this during some of the breaks but did not have time to show the whole thing. Veljko Milkovic is the inventor of the popular 2-Stage Mechanical Oscillator, which produces many times more mechanical work that it takes to run the machine. This will be posted on YouTube at some point so everyone can watch it and learn more about his work.
Stephen P. McGreevy gave a very interesting talk on natural VLF radio recording. The Earth and atmosphere is constantly creating all kinds of music and other sounds, which are not audible to the human ear. Animals hear these sounds building up before an earthquake and that is how they know an earthquake is about to strike so they flee the area. Even if there is no natural disaster coming, these sounds are constantly around us. Stephen shows us many of the places where he traveled to record these sounds, he demonstrates the difference between the sounds and how different places sound different, various antenna methods to pick them up the best and anyone can get the receivers through his website so you can experience this as well. This is a fun and simple way, especially for children, to get in touch with the world around them. There are also schematics to build your own receiver that are open sourced on his site. This talk is highly related to Eric Dollard's Advanced Seismic Warning System.
