Hi all,
Tried split triggering with the system.
I moved the magnets on one rotor to between the mags on the other.
Planned on having alternating triggering with twice as many spikes while alternating mags between the 2 rotors.
If the battery rotate system stays in place then the tops of both run coils must remain tied together and the ground (from pos of charge batt) is common.
The trigger wires from the tops of the 2 run coils are the only wires that are separated along with the 4 collector wires from each run coil bottom.
I had two pots setup and got one running good and then hooked the 2nd.
It goes into self oscillation mode and stops spinning the rotors. More than double the amp draw of one side.
The oscillations alternate according to the 2 channel scope shot
very interesting.
Next test might be to run separate batteries for each side without the rotate system.
Also I'll try split triggering with mags aligned on both rotors.
bro d
very interesting.
bro d
