S1R9A9M9 Time Line Data
  • S1R9A9M9 Time Line Data
    S1R9A9M9 Reference Time Data Given
    Important TIME LINE data here today, for the You tube videos of the Briggs engine that ran on water in Georgia.
    June 24, 2008 summer. Successful 2 video demonstrations of 18HP Briggs mower engine running on water in carb. Son removes engine from shop and puts it in back yard with father on cement block with large holes for main shaft and other hidden items.. The shop technicians had reconfigured the water fuel system , not Nathren father who is not tech minded. ( from original web forum data sheets)
    August 2008, two months later. The back porch scene Georgia, Nathren father, failed attempt to run same engine on water in carb, with JUST S1R9A9M9 coils assembly and resistance lightbulb load on battery. Helper holds camera . PROBABLY NOT the son , also Nathren, since he was a technician who worked on designs in work shop with the 2 other technicians. Son would have known about all parts used on Briggs engine to run it properly.
    "The Smack" two videos were on the later December 2010 at Nathren's property. He got donations for charges incurred for the 1000mile trip. Just another young mechanic guy who thinks he knows everything. Several common tests were not done with the Briggs engine at that time. Engine again, not running on water. Son not present.
    February 7, 2011. Nathren senior attempts to disassemble engine and discovers rust from engine setting too long , from 2008. Piston cylinder scored and valve(s) stuck. This proves engine would not run from Aug 2008 + Dec2010.
    Conclusion : Briggs engine not proven could not run on Hydrogen gas derived from spark plug electrolysis and water vapor pressure from repulsion of ions. Original extra parts such as Inverter + special Relay, alternators hook up, were NOT put back on engine for proper RETESTING, and would not have worked any way due to NO available engine COMPRESSION
