.... and some things to do with it
I) Opening Accolade
Of Tesla's celebrated forgotten inventions the Mechanical Oscillator proudly stands second to none in obscurity. While many claim to have heard of and to have opinions about its much praised or maligned but generally completely misunderstood sophisticated younger brother, that Monarch of Machines, the Tesla Turbine, few will claim any knowledge at all about what is arguably the best piston fluid heat engine design ever.
Here are a few quotes from Tesla himself about the engine and how it came to be:
The Problem Of Increasing Human Energy, With Special References To The Harnessing Of The Sun's Energy
The Century Illustrated Magazine, June 1900.
".. I finally conceived a combination of apparatus which should make possible the obtaining of power from the medium by a process of continuous cooling of atmospheric air. This apparatus, by continually transforming heat into mechanical work, tended to become colder and colder, and if it only were practicable to reach a very low temperature in this manner, then a sink for the heat could be produced, and energy could be derived from the medium.".
".. the primary object of which was to secure the greatest economy of transformation of heat into mechanical energy. A characteristic feature of the engine was that the work-performing piston was not connected with anything else, but was perfectly free to vibrate at an enormous rate."
".. the engine which I have named "the mechanical oscillator." In this machine I succeeded in doing away with all packings, valves, and lubrication, and in producing so rapid a vibration of the piston that shafts of tough steel, fastened to the same and vibrated longitudinally, were torn asunder. By combining this engine with a dynamo of special design I produced a highly efficient electrical generator, invaluable in measurements and determinations of physical quantities on account of the unvarying rate of oscillation obtainable by its means. I exhibited several types of this machine, named "mechanical and electrical oscillator," before the Electrical Congress at the World's Fair in Chicago during the summer of 1893, in a lecture which, on account of other pressing work, I was unable to prepare for publication. On that occasion I exposed the principles of the mechanical oscillator, but the original purpose of this machine is explained here for the first time."
"In the process, as I had primarily conceived it, for the utilization of the energy of the ambient medium, there were five essential elements in combination, and each of these had to be newly designed and perfected, as no such machines existed. The mechanic oscillator was the first element of this combination, and having perfected this, I turned to the next, which was an air-compressor of a design in certain respects resembling that of the mechanical oscillator. Similar difficulties in the construction were again encountered, but the work was pushed vigorously, and at the close of 1894 I had completed these two elements of the combination, and thus produced an apparatus for compressing air, virtually to any desired pressure, incomparably simpler, smaller, and more efficient than the ordinary."
References:
Tesla's Oscillator and Other Inventions
by Thomas Commerford Martin
1894-01-02, US Patent 511,916 Electrical Generator
1894-02-06, US Patent 514,169 Reciprocating Engine
1894-04-10, US Patent 517,900 Steam Engine
@ C. Kurtz 2014 This content is offered under CreativeCommons by sa-3.0
I) Opening Accolade
References:
