So Tsiriggakis is to my understanding a previous Greek military engineer who has posted about 6 videos, one or two related to a "gearless different" he has patented which he said was based from his study of the Antikythera mechanism (I say, God rest his soul, but it is better than Tom Clancy). He has 2-3 videos for his "counter-gravity mechanism". He also has a simulation of his counter gravity mechanism flying a plane off into space. Here is an informative 1-2-3 video of his counter gravity mechanism. I'll discuss both exactly what he is doing and why I think it may work. We will reveal the secrets of the sandbox not known for the ages
Antigravity Mechanism - http://www.tsiriggakis.gr - YouTube
So we notice from from about 0.15 - 0.20 two counter rotating pendulums (which again is why I thought to look at this again). Now, and it took me a while to realize this, in this machine this motion never happens in isolation. I.e. I thought there was a motor in the center box, there isn't. You can look at the built machine working here Antigravity Mechanism - http://www.tsiriggakis.gr - YouTube
Next is the second motion added, this is from 0.23 -0.30 of the video. So, if not a motor in that center box, what is it? I puzzled a long time on that. I finally got a description from a paper which I still had to learn what it meant. It is a 1:1 planetary gear 2 suns two planets with one sun locked in place. If I were a gear head, maybe I am now, I would have known to call it another name, it is a differential. I'll be honest, I basically replicated things up to here with gears from a hobby shop, enough to see that the motions were as presented but the darn gears would not stay in place. This led me to learn of "bevel gears" for right angle differentials. I thought I am going to have to go to a machine shop they will charge me a thousand dollars I don't care if it flies to Mars I want something cheap. Again it has to be a 1:1 differential, but low and behold I found that as a robot kit add on. One inch 1:1 plastic differential gears about 20 bucks, so I'll order that soon, but again I got far enough to see it is a differential driving the motion in the center, maybe I should have taken a clue from his patent.
So what do we have now, two counter rotating pendulums which draw out a figure eight over half a hemisphere of a sphere. A paper went on to describe how this motion led to an oscillating increase and decrease in force registered on a scale. This makes sense from what I have thought about previously. Yes they are always going at the same speed, but when the two masses meet up at the top there will be an upward force, when they both hit bottom, a net downward force of the same amount. It would just want to vibrate or oscillate.
So now we have from 0.33 to 0.40. I haven't replicated this and here is where he is either a liar or something much different. Why do I think this may work? Because I've toyed around with gyroscopes. A spinning gyroscope can sit over the end of a table without falling. He is introducing a gyroscopic or precessional aspect of motion. Now when the two weights meet at the top they are at the center of the circle of gyroscopic motion and there would be no or almost no effect. At the bottom they are at the circumference and the gyroscopic effect would be most pronounced. Bruce DePalma spoke of an anisotrophic change in mass with rotation.
I got 90 percent through steps one and two and three seems pretty easy. Once I have beveled gears for a differential I may be able to replicate it but if I am not mistaken, Tsiriggakis, instead of employing a consistent change in velocity, has employed a consistent "anistrophic" change in mass. For me this may take weeks (hopefully not) to replicate, for you gear heads out there, it is a differential to make this motion, it may take you an afternoon or day or two. Have fun and may we all be just, peaceful and productive.
