Hi all,
I'm new here on the forum, so let me introduce myself, I'm Jp from urcoffeetastestoasty.
It's been a few years of building little motors now. (imhotep, muller, mike hmm, etc
The motors I have built are based on concepts found in the free energy generation book.
If you are interested in the older urcoffeetastestoasty builds, here's a few videos:
http://www.youtube.com/user/UrCoffeeTastesToasty --> motor marathon & motor codes
I also have a website: http://urcoffeetastestoasty.weebly.com/
Now I'm working on a spintop with axial type, but still air core coils.
This is the setup plan:
It has 4 generator coils of quad-filer wire, each two in series and 10 meters per strand of 0,3mm wire
The motor is 2 coils in series and a single strand of 40 meters 0,3mm wire.
A trigger wire is wound together with one of the motor coils and is 0,1mm of 20 meter.
The bearings are s623zz, very smooth.
There are 3 special biased trigger coils (which are: two triggers in series at 90 degree phase angle.)
These special trigger coils will separate the pre-charge, charge and discharge cycle as well as the generator timings.
The point is to store the radiant and pre-charge the run capacitor before the battery fills it up.
The generator is timed for incoming magnets and will be oscillated using a joule thief on the trigger.
Additionally it has small copper tubes as rollers, the copper is induced by the rotor and starts rotating itself.
I hope you like it!
JP
)The motors I have built are based on concepts found in the free energy generation book.
I hope you like it!
JP
