Originally posted by John_Koorn
So my prospective was that If you were using the transformer function, you could use one trigger. But if not you would use one trigger per transistor.
But it could also mean that he had the extra wire there so he could play with the transformer function if wanted and was just an extra wire hanging there when not in use, and there is no such thing as more than one trigger wire.
I just seems to me the lameller currents would not have the same effect without a trigger strand per transistor...
Or I could just plain have the whole thing wrong from the ground up(most likely).......
Les
I can guess that John B wound two of them to see if both in series or parallel or just one by itself worked better Or maybe he already had the coil lying around.
, where the very Nature of Radiant Electricity shows up it self in different variants to make it convienent to be Engineered in avarity of configuration to avoid duplication and reverse engineering .
