@John_Bedini
Alright,
so i watched the clips.
As i see it, the voltage is a little lower then acid filled battery's.
The alum battery charges much quicker
The alum battery can be drained to 0 volt, without harming the battery
The alum isn't toxic.
The alum just crystalizes when it dries up.
(i read on wikipedia, that when heating alum, it liquifies)
Therefore an alum battery should always be able to recover. just ad the water and pump the power in.
As i see it, you only used a 1 amp panel.
This tells me you are pulsing the system like a joule thief style puls, pulling energy from the ambient? Hence tickling the cell to pul power from ether.
Maybe i am way of here?
How about the power the cell holds? Say one uses a 10 amp/h battery on acid, is it still 10 amp/h on alum ?
Then again with that charge curve, i recon that not continiously pulling power from the alum battery, say pulsed, the alum battery will hold its charge longer?
My 2 penny's of thought.
Could you enlighten me some more?
P.s. did you guys see the opst i did on the low lenz generator... pretty nifty stuff
cheers,
Rene
Alright,
cheers,
Rene
