Crystal Light Kit
by John Bedini
This kit is an easy to use Crystal Light Kit designed by John Bedini.
It includes everything you see in the picture:
by John Bedini
Crystal Light Kit. The kit consists of Alum, Copper and Magnesium and when properly placed and coupled with the proper electronic circuit will produce a bright LED with an endless supply of electricity.
The Crystal Light Kit has been designed as an educational aid in combining elements to produce an electrical charge, a curiosity of sorts.
By just adding water the chemical reaction begins, and the electrified crystals will begin to grow as they produce electricity, which will power the LED light. The Crystal Light Kit will perform for many years using just water as its only fuel source.
If your crystal dries out it will not damage the lamp and can sit for many years in a dried condition until needed. By adding just a few ounces of water around the crystal will return it to its previous working condition and full
brightness!
The Crystal Light contains five basic components which are assembled as shown below. The five components consist of a pre-assembled base, copper bowel, magnesium round, plastic ring and food grade Alum powder. We are sure you will find this fascinating as it powers up its LED. Kits are sold with a White LED and separate LED heads can be ordered in Blue, Green and Red colors.
brightness!
- stand with uprights
- oscillator and light in box with switch
- copper bowl with semiconductor layer black oxide (cuprous oxide)
- instructions (just add water!)
