Hello all, i just bought the DVDs on crystal batteries by John B and Chuck, and decided to build the cells and the oscillators as close as i could. all i can say is... Mr. Bedini is right as usual... after so much experimentation on the other forum, the alum batteries proved to be ahead of the game so far, and the simplest. these are putting off an awesome 1.9 volts each at around 90Ma shorted. the first pic shows 4 cells in series powering 3 of a very special kind o LED, these have a 360 degree light radiation and they use 3.6 Volts!!, these are 3 led, look how beautiful.... no problem reading with these on, apart from these 3 LEDs there's no other light in the room. the next pic shows 3 newer cells with a bigger copper cap, they are each running an independent sg oscillator described by Mr. Bedini in the dvd, I tried to build it as accurate as possible. they all have different coil sizes, the smallest one (about 25Ft 30AWG) is the faintest, the biggest one is middle bright and the middle size coil is the brightest... that's John's sugestion, about 45Ft. Mr Bedini you have a very grateful student here, thank you very much. i know you are giving what you can and it is a great basis to study the radiant energy... many blessings,
carlos
carlos
