Will I need to be careful of duplicating the oscillation of my body or the roof above me trying to find the pattern which allows the surrounding natural energy to flow with the least amount of resistance?
Basic Monopole Diagram
This is a sticky topic.
you just need to start reading, especisally tesla and leedskalnin. its not easy to answer your questions. an LCR meter is not what I am talking about a tank cicruit is about resonance. it is designed using mathematical formulas. resonance in a circuit is different than free air resonance, and different than the schuman resonance and different than resonance in solids...... or resonance in solids with cavities, or the permeability of a solid based upon its molecular structure. way too deep of a subject. the monopole draws the dipole from the vacuum using the coil, the resonance in the circuit reduces current draw from the primary and helps to push the dipole into the charge battery. resonance of the quantum state is done in the center of the coil. you find out the resonant point because it gives you the best charging. it is sympathetic resonance between all parts of the circuit. study Johns amplifier patents you will understand the SG (feed forward designs)Originally posted by [email protected] View PostWill I need to be careful of duplicating the oscillation of my body or the roof above me trying to find the pattern which allows the surrounding natural energy to flow with the least amount of resistance?
Answer to your first question - Yes.Originally posted by [email protected] View Postok another newbie question. Does this mean that everything has a specific point where it will oscillate? Do you have to pump in lots of energy into something to make it oscillate? Or can you just play a digital recording of a sound and cause something to oscillate using very little power? THANKS!!!!!!!!!!!!!!!!! Rick
Answer to your second question - No.
The third question is more complex. Yes and NOT always. Beside fundamental frequencies there are also sub and harmonics. You can magnify the effect by using extracted harmonics of resonant frequencies and further limit the energy while achieving better result. I think we're floating away from basic monopole idea but since you asked
Vtech
Vtech
yea what he said...... thanks for the board Vtech!!
You're welcome Tom. I'll try to either take a picture with all peripheral components connected or draw them and post in Beck thread. This should help assembling everything together.Originally posted by Tom C View Postyea what he said...... thanks for the board Vtech!!
Vtech
John: NEW DEVELOPMENT WITH SSG THIS IS MIND BLOWING!!!!
Name: 01[1] starter.JPG
