Third Bedini Build � She goes like a rocket!
Wayne,
I am not trying to discourage you, and i wanted to state this plainly. I see a lot of awesome looking builds that never perform well, and I see a lot of people just build junk, and it does not perform well either. the goal and focus of all this is to get this world energy independant, and the SG is the perfect tool for this. so many focus on rpm or on the fact of "hey its running: but it charges terribly...... its a common problem. with rotored sg's there are many parameters. your mag bearing rotor is one such permutation. I just want you to have success.I am glad to see you have a well rounded background that will help trmemdously.
Hi BroMikey.
As you may know, boating, camping and fishing in Australia is a national pastime with hundreds of thousands actively involved in this recreation? Whenever I share about new energy generation, the first thing most Australians relate it to is a camping application. If an invention came along that could viably supplement a campers energy needs; was reasonably priced, efficient, quiet and non polluting, you would definitely have a market in OZ; and no doubt in many other countries as well!
Hi Archangel,
If you visit Peter Lindemann's website and view the E.V Gray page (in the Radiant Energy session) you will get this Camper's Inverter that was build by the EV Gray enterprises way back in 1978..i guess. why not have a thread on replicating this Solid- state Power supply.. see the features its awesome and just what acamper would love to have...(72 hours of power back up over the week end.) amzaing indeed!
Hi BroMikey. - From my research, there are a number of people who openly claim that their energy devices develop enough electrical power to run the device and produce excess energy on top to power other items. In other words they self run and produce usable energy on top;
(That is if we are to believe the many hundreds of testimonies and stories across the web, quality documentaries and endorsements from individuals at the highest levels of the scientific community.)
If there is truth behind this compelling pool of evidence then the Bedini energizer should be a very strong candidate for self running so that the primary battery can be switched over and the flywheel’s torque utilized and geared up to drive a small, high efficiency generator producing conventional DC power with enough current to power the coil and circuit.
Perhaps the degree of separation between the Flywheel and generator needs to have an additional step or two in place, (to avoid a closed loop system causing eventual inertia,) however ultimately, I believe this is possible.
“A self running Bedini energiser that requires no primary battery; uses its own torque to power itself and charges a bank of batteries with genuine free energy ... and that system could be used to power anything from power generation for camping, power for your house or indeed, a power station!”
There I’ve said it, (and probably got myself into trouble,) however I’m sure the above statement has crossed many people’s minds and I’m also fairly sure it’s not as easy as I make it sound; but I also believe it’s absolutely possible.Last edited by Archangel; 06-11-2013, 05:02 AM.
Originally posted by BroMikeyIt cost John B $30,000 with the current Bedini energizer to get free energy at 2-3000 watts with an input of 10X less.
Still 3000watts is small considering the many thousands of pounds of batteries require, wouldn't you say?
