I'm in the process of changing my 5 filar, 18 AWG, bicycle wheel SSG from repulsion to attraction mode and wondered if it would be beneficial to also change from the single diode output configuration to the bridge rectifier output so as to collect the "Tesla Impulse" when the switch closes?
Here's the circuit I'm talking about.
I don't know if the gain would be offset by the additional voltage drop through the extra diodes or not. And would this arrangment allow the secondary battery to be swapped with the primary, or would it still have to go through a cap dump to allow swapping of the batteries?
And a further question about the FWBR ........I understand "having good sucess", but does it actually increase charging over the single diode or not?
If it doesn't actually increase output, then I'll stick to the single diode out. But if it charges better, I'll add the extra matched diodes!
