You know what else is interesting is that I'm hearing a chorus effect coming from the SG now. I'm speaking from an audio standpoint...when you hear two audio signals phasing in and out of each other...and it sounds like a watery chorus effect. It's a little discerning haha.
Also your recorded tracks sound pretty similar to what I hear on my machine. Mine has larger wire and two coils so of course it will be a little different but basically the same. And you are right in that the very slightest change on resistance does have a drastic effect, now you have figured out a way to monitor using an audible indicator. Setp a timing light with an led and it will all paint a bigger picture for you. Don't leave a timing light on during the run, just spot check with it. It will draw power from the circuit so you don't want it connected any longer than to just take a quick look at what is going on. You can use two led's like I have with different colors and see both the coil charge and release. Just connect them in opposite directions, one lights while other doesn't and then they reverse.
