From the reading I have done, the best way to run the SSG is with a battery as the primary, and at least the same size and type
of the battery being charged.
I have also read that using a power supply that is at least capable of 3 amps is an acceptable way of running the device.
Is there some insight into this that anyone could provide? Why is it better to use the battery?
What if I use a converted PC power supply that is capable of delivering up to 12 or 13 amps at 12V?
Would that be ok? I know that it will run the device, but will it work as well for charging?
If so, why or why not?
As always, thank you all for your valuable information.
It is we who must seek the Truth of the universe, to walk the path of enlightenment.
