Hello friends,
I have replaced the SG wheel with a "tiny window motor" (from renaissance charge).
It just worked straight away, I just laid the stuff over the coil, no fixing it, and it started spinning like hell.
I have read 2000 rpms (was 170 ), but I think my speedometer has incorrect reading.
anyway, I plugged in my 6v alcaline battery I'm trying to rejuvenate. over the night, there was a strange smell around the bench, and the battery appeared to be way, way, heavier ! and it apparently got down to deliver 4,20 v (was 5,20). And, it was hot on the outside.
So I don't know what happened here. Did I damage my battery permanently , even with pure "negative" energy ?
What I'm sure of, is that with the SG normal setup , it never happened like this in a 8-hour span. It is definitely, to me, the introduction of the tiny window motor (neodynium magnets) that did so. So, it appears to boost the charge out there, (no idea of the amps in / out though) but also, to make the negative energy do bad stuff to my batteries ?
I thought that "neg energy" would not cause heat ...
I'm like a chicken in front of a square egg....
perhaps the wall powered D.C source???? Try with Battery input (hope you have not ruined your 6V alkaline Altogether
) for this trial....
) have discovered what a Bipolar- Monopole is doing to the SG Energizer
