Hello ALL, im a new member, i just finished building my monopole using the instructions provided for this experiment as accurately as i could, yet it's still not working, sorry to bother you with this, but i need help, i have rebuilt the circuit 8 times and it seems to be accurate, but obviously there's something im doing wrong... here's a picture/diagram of exactly how i wired my circuit, and another one of the rotor/stator, if any of you can spot the mistake please let me know. wired this way, the coil gets Really hot (above 200F) also the transistor. when i crank the shaft the motor doesn't start, and it seems like the poles are NOT shifting, it stays on attraction mode. the picture/diagram is based on the exact wiring i have on the board, this is my 8th attempt at rebuilding the circuit from scratch with new parts. all parts were tested and so were all the connections... thanks!
, now i check and re-check a million times all the components and connections, i even changed the transistor, the one in the picture is brand new.... it's got to be something else, maybe the wiring... by the way, thanks for teaching me a third way to check the transistors!!... cheers
) Which it does not.
