Matching Transistor Problems
Hi All, Just read thru the entire intermediate handbook and have a question. I know up until this book was published that we used the HFE portion of the multimeter to test and match the transisitors. Is there any advantage of using the tester JB used as described in the book over the HFE test?
BudDo not procrastinate! Make something happen...even if it is wrong. Once begun half done!
Yes, it provides more current to the base to full open the transistor. the "opening" is not linear, you want to see what the transistor does when it is hit enough current to fully open it.Originally posted by Forrest View PostHi All, Just read thru the entire intermediate handbook and have a question. I know up until this book was published that we used the HFE portion of the multimeter to test and match the transisitors. Is there any advantage of using the tester JB used as described in the book over the HFE test?
Bud
first I have to say that I use the circuit in the Bedini SG intermediate book, page 11.
I built the circuit today, I tested MJL21194G transistors.
I had to replace the pot and the 27k resistor with a 62ohms to get .103A on the ampmeter. I have bougth 30 of those transistors and they all performed almost exactly the same from .102 to .104A. I have also tested a 2N3055 in the cirduit and the 2N3055 give around the same result.
I have rebuilt the circuit twice and it give me same result.
I have search the forum about this topic and I did't find a lot of info to help me.
Am I on the right thread to talk about that ?
YvesLast edited by Yves7772; 06-15-2013, 06:13 PM.
I tested just 6 previously used transistors. mjl 21194's on a tester I got on ebay. Does the result mean none are matched? Or is it close enough?
# hFE uf mV
1 21 633
2 25 644
3 23 633
4 27 638
5 25 623
6 25 643
Tom,
I take it without having the book in front of me that you run 250mA through the base and match on that basis?
Is there any value in using smaller variable resistors on the base so as to match the transistors in situ on the board and in operation?
Is it possible to tune the individual base resistances so that mismatched transistors can be used?
I'm thinking in terms of locations where even getting a MJL is difficult let alone 100's in order to match them.
Thanks for your advice
James
That sounds about right for the base current. I don't remember exactly what mine is set at. I have never done what you are suggesting it should be possible. You would have to tune your circuit to the lowest transistor you have. If you need marched ones we sell em.
