I would like to make some modifications with my circuit. Instead of 12 volt source, I'm replacing it with 9 volts. Now, my question is,
1. Would I have to change the size of my Trigger and Drive wires in the coil? My current wire size is 23awg and 20awg, respectively. If I have to replace it, what size of wire is best suitable?
2. Would I also have to change the length? I've got approx. 130 ft right now.
3. The handbook specifies that I use MJL21194 Power Transistor, is it possible that I use 2N3055 as a replacement? There's not much difference in their amperage, which is 15 and 16 amp respectively, but there's a big difference in voltage and wattage.
4. This is unrelated but I would like to get higher torque from the wheel of my rotor, does using Neodymium Magnet increase the torque? or I will just stick with the ceramic type magnets.
Thanks in Advance! More Power to EnergyScienceForum...
