There has been much discussion in the old Yahoo groups 2 and 4 as well as here about replacing the #23 8-filar coils on the r-charge 10 coiler. I know there are also issues of replacing the electronics with matched components and replacing the rotor, but I'd like to concentrate here on the coils.
As I understand the discussion so far:
1. Wire must be #18
2. Coils must be 4 filar (except the master which needs a 5th for trigger - it remains unclear to me if trigger needs to have one wind to itself before starting power coil windings)
3. each wire should be matched to a resistance of 1.2 ohms after allowing for any resistance given by the leads used to measure the resistance. This should be done by winding and then cutting the wires down to 1.2 ohms resistance.
4. Each wire should also be matched for impedance using a LCR meter; this should also be done by winding the wires and cutting down to the proper impedance. I don't understand which to do first, resistance or impedance.
5. wires should be litzed, but it's not clear to me if the trigger should be litzed with the power wires on the master coil
6. core should be copper coated R60 welding rod. The current coils that came with the 10 coiler has significant amount of core sticking out on both ends to help sticking in the coil holder on one side and about 1/4 inch on the side that is close to the rotor.
7. Finally, it's not clear to me that all this has been passed by John B, but most of this is from people who quoted what they heard from him. Also not clear is if the coils need to be matched to electronics on board or this is handled by the tuning.
This seems to be quite a complicated technical undertaking which will require a lot of space and extra hands or special winding jig as well as LCR meter, if not other equipment I'm not aware of yet. The great advantage, I thought, of buying coils from R-charge was that Rick said each coil was wound the same way every time. That may be but there is no source, that I'm aware of, of coils that fit the specifics above (if indeed they are correct). It seems we're each in a position of winding our own coils which should please the ebay sellers of LCR meters. ;-)
If all these specs work out to be true, or whatever specs we get from John B, it would seem that many of us are in need of new coils. If anyone is in a position of producing coils to the exact parameters that John B requires for the multi-coil machine, I'm sure there are some of us interested in buying them from you rather than each of us investing in the coil winding infrastructure.
I'd love to hear anything wrong with the above specs, or if anyone is interested in winding coils commercially.
thanks,
howard
1. Wire must be #18
thanks,
howard
