I got my Bedini SSG working last week and I have been able to charge a 18 volt and a 24 volt drill battery. It seems to be working good as far as I can tell. However I have been trying for 6 days to bring back my motorcycle battery. It will hold a sitting charge around 11.8 volts but quickly drops when I put a 300 mA load on the battery. While charging with the Bedini the charging tops out at 12.84 volts and hasn't gone any higher. I read that you need to charge, discharge, charge, discharge several times.. I wasn't seeing much of a rise in charging voltage or capacity voltage so I thought I needed to discharge longer. Tonight I accidentally discharged to 5 volts, hopefully I didn't kill the battery (its recharging now)
Im sure it is heavily sulfated but I figured that it being such a small battery I would have seen better results by now. I see it charging but I do not know if my Bedini SSG is actually working as a desulfator or am I just not doing it correctly or it is going to take longer? Or maybe my plates have shorted out.
I am trying to see the amperage going in and out to the battery. If I am reading my multimeter correctly while set to 10 amp mode I am seeing 0.55 coming from my 12 volt power source, and multi meter set at 10 amp mode going to battery it reads 0.24.
Any help would be greatly appreciated as I am getting anxious to start riding my motorcycle again, while trying not to have to buy a new battery.
