Hi John,
Yea I'm with you on that. AS ironic as it can be I just blew my relay! Not sure what happened but I came in the room to check on things, arduino was still running so it was not a power problem there. I glanced at my volt meter I had across the caps and it was buried, a 50v meter at that. I switched off the machine and touched the relay, very hot, caps were quite warm too. So I grabbed a gator clip and a 100 ohm 2 watt resistor to drain those caps. Oh well this kind of thing happens but it is funny we were just talking about "what if".
I was lucky because there was no damage to my bedini machine, it seems the aurduino is ok too but the relay had cooked. I had run this thing for days at a time in the past but I don't know, something went wrong. Blahh, oh well. My machine is much more efficient without the cap dump circuit anyway.
Sorry guys I was going to take a video and show but now the dumper is busted and I am not in a big hurry to fix it.
I was able to read the voltage into Arduino later on. But the numbers are very unreliable as a single value. I had to take the average list of readings to make a decision. It was still pretty unreliable at the end. I had used a relay to momentarily cut off the battery from the circuit before reading the value into Arduino, using the voltage divider circuit. All those decisions I was making from the Arduino. My thought was, if I get a voltage reading into Arduino, I can make decisions to stop the charge as I need. I could also make other useful decisions from Arduino. Then, I don't have to worry much about having an overcharging situation. Back then I tried it on a battery. I need to try it on a cap and see if it gives me a more stable reading.
