Hello all,
I have a reworked r-charge 10 coiler that is able to charge up a 215AH bank from a 215AH bank. I got the large comparator made by JB and have been told that the output of the machine would likely burn up the comparator. So I've tried running the output from one coil only through the comparator, but wonder if any of you have done that?
Those who have used the comparator know that there's a post for the output from the collector diode and the positive of the charge battery to attach to. That is clear enough. There are two other posts. One for the negative of the charge battery, clear enough. The third is to connect to the common connection between primary positive and charge negative on the energizer. The interesting thing for me is that the energizer is running off a 215AH bank and charging another one. So that common connection on the energizer is between those two banks. I have no place where the 25AH battery being charged by the comparator connects to primary. So currently I have that post on the comparator connected to the common buss on the board for that coil. The 25AH batter is not fully charging and I'm pretty sure that's because of how I have it hooked up.
Anyway, if anyone has tried this and has a suggestion or method I'd appreciate hearing about it. If I can make this work, I envision running all the coils though comparators to separate batteries, which I think would solve the last few little synchronization problems I have.
thanks
h
thanks
h
