my problem is that when I give the impulse to the wheel, it stops after a while, do not think that the weight of the wheel, my engine specifications are:
the gauge of the wire is 23 awg (power) and 26 AWG (trigger), the length of each wire is 100 meters
the number of turns on the spool is 530
the rotor has 16 magnets are ferrite and grade 5
the duration of the spinning rotor is 6 min with 10 s
the 2N3055 transistor is used
Charging the battery is 12v and 1.2 Ah. It is rechargeable sealed lead-acid battery
Is a single coil machine
Photo Ahead:
Photo Ahead:
