Coilwounddirection SSG startersguide1 and Complete beginners handbook
Well people i finally got it, the attraction mode produce better mechanical work of the wheel, so that means more free pulses as result!Last edited by BEDINSSGUKRAINE; 01-10-2014, 09:51 PM.
Thanks John,
Once I decreased the spacing, the rotor starts and runs much easier now. With less primary battery drain I can see that the attraction mode is far more efficient when comparing it to the repulsion mode. The transistor remains quite cool and balanced with the ambient temp. however the coil gets about 8 degrees hotter than ambient, in its center (measured with an infrared thermometer), is that in range?
Perhaps you can answer why is it that the SSG uses two different diodes but the SG uses one type? I have not found the reason anywhere, I must be missing something. But I'm eager to learn as much as possible.
Here is a pic of the SSG I built until all the parts come in for the SG
Kevin, I think this is fairly normal. Most likely it's because of your small wheel which does not have much mass to store enough kinetic energy to keep it moving. This is why a large bike wheel is recommended.
OK let me explain a bit further. Perhaps someone can comment as to these observations?
I have constructed the coil in a counterclockwise direction, leaving me with a south pole on top for an attraction mode with the N face magnets on the rotor. However it seems when the magnets on the rotor are facing N outwards, the tolerance of the spacing between the magnets and the coil is much smaller and requires a more forceful push-start. Once running, which I wasn't able to do earlier because of the 1/4" spacing did not allow it to start, I have decreased the space to about 1/8" which now allows it to run, albeit with a much more forceful start. [The circuit is straight out of the book, where the top wire goes to the positive of the battery]
Now, when I switch the magnets on the rotor to S facing out (repulsion mode), the space tolerance is greater and I hardly need to push it to get it going. Although, this setup creates more rpm, more voltage on the charging battery and more drain on the primary than when the magnets are facing N. Unfortunately, I do not yet own a scope to check out other factors.
Everything remains cool during both methods and without any humm or buzzing, just the rotor moving.
Has anyone else experienced this and whether the force needed to start the attraction mode is normal? Or am I missing something?
Thank you.
I'm new at this,
The coil winding is still leaving me a bit stumped. I did wind the coil as illustrated, where S is on top, but in order for it to work I had to turn the magnets on the rotor S facing out, instead of N. Is there something I'm missing? Are you running it with North side facing out with a south top coil?
My ssg is working with the following:
3055 transister
4001 diode
4007 diode
100 ohm resister ( experimenting with different sizes up to 470)
4 Ferrite magnets 90deg
rotor is a roller blade wheel with nice bearing action
iron welding rods as suggested
22 and 26 ga wires 600+ turns
ne bulb
fullriver 12v 110ah battery primary
various different charging batteries for experimentation
I'm working on the SG 7 circuit, but NE bulbs are back ordered.
Thank you
Originally posted by mrbeale View PostI just read the book last night , good book and worth a read for beginners.
My question is ive built what I think is an SSG I have one transistor one resistor, the coil is two equal lengths of magnet wire one .56 other .8 wound(not twisted) around the welding rods on a plastic spool. etc.. one of each componet, is that the SSG and the SG is whats in the book a 7 transistors 7 resistors etc and and single trigger wire.
Whats the perforance difffernce between these two pls?
Should have I build and SG first for exeriental reasons??
For the 7 transistor model, you still only need 1 trigger - just connect the triggers together on all the transistors.
The diagram is in the book to show how to wire all 7 together.
A more relevant question to ask about the SG vs SSG is not the performance difference but what is the difference. As stated above. SG doesn't charge anything and the SSG does.
If you have a small model with a small coil, you can run it in SG mode and you probably don't need a neon on the transistor for protection, but it won't hurt if you do. I would recommend just doing it to get ahead of the game for when you build a coil big enough for it to matter. Then you can just learn about the mechanics of how it operates. To make it an SSG, just add one single diode and a secondary battery to take the electrical recovery and that is about it.
Originally posted by Prinsloo View PostThanks for replying, you should rather call it "the new mode/ method" than the "this other mode/ method" ?, I know it's not new as such, but it is the first time that it is published ? !
Aaron don't throw small builds away, look at Woodys build for example!, I myself has seen weird stuff (not mentioned, that I know of) on my system, seeing like 8 currant shifts (gear changes ) in like 2 - 3 sec on my system, repeatedly depending on the configuration.
I have seen voltage spike almost double with no additional currant from the primary by just making small changes to the system, (I'm still chewing on this one !)
I know with so many variations on the SSG build from roller-skating wheels to wheelchair wheels, single wire coils to 20 wires per coil, ceramics or neo's, SSG to SS SSG, diode charging to cap-pulsing, different batteries types, etc. etc., its a hat full !
Aaron you guys need to get a way to consolidate all this! How? I don't know, there is so much feedback and information out there that might get lost!
Just a though, start a new thread and ask the community here for some ideas/ways of how they want to participate/commit to this forum and make it work even better?
Theunis
On a small build, I just corrected my numbers and got 1.6 COP and that doesn't even include the mechanical work. At first, I thought it was 2.38 then I thought it was 0.6. After carefully going over everything, it is actually 1.6, which is phenomenal for this machine and I'm only using one power winding and it has a really small coil.
The new book is definitely the best compilation there ever has been for the SG in terms of an actual handbook. All the other stuff - some will be in the intermediate book. By the time the advanced book is released, there isn't much else that anyone would really have to know about it so most people beginning can focus on building instead of asking questions. So much of the time is spent just figuring out what to build and how to put it together and we know this book will save them a lot of valuable time.
Thanks for replying
Hi Aaron
TheunisLast edited by Prinsloo; 12-11-2012, 02:11 PM.
Originally posted by Prinsloo View PostHi Aaron
Please clarify " this other mode " do you mean attractive or repulsive mode?, also have you been using it with a cap-dump system or straight radiant charging that gave you the better results?
Theunis
With that one (little SG), I only used the spikes. On my bicycle wheel one, that was using this other mode as well and that was with cap dump using a trifilar coil with a mechanical switch. I always thought that gave me the best COP. But...
I recently ran this energizer: https://www.youtube.com/watch?v=xiZ86Dqckm0 with a new circuit - typical SSG with a MJL21194. Used 1n4001 for both diodes. 60 ohm resistor in series with a 1k 10 turn pot meter. Coil is so small it doesn't need a neon. Runs fine without a battery on the back. I never did a charging test with this little machine because I never thought it could do much. Well, I ran it on a 18v nicad tool batt and charged a 18v nicad tool batt after it was discharged with a resistive c20 load. The input vs output results are shocking and that doesn't include mechanical work.
I need to have a few people look at the numbers and calculation method first before I post anything on it, but it is the highest COP with a single battery:battery charge that I've seen for the basic SSG. The roller skate wheel was spinning at 4500 rpm and using neo magnets, which you're not supposed to use in the normal mode anyway. I have to do more tests, but I'm thinking so far that neos are actually beneficial for the new mode - helps with mechanical but also recovery. Don't quote me on that because it simply needs to be done with a test with the new mode with wheels that have neos and one with ceramics to see the difference.
Originally posted by Aaron Murakami View PostHi Forelle,
I've run mine in this other mode since the beginning - 12 years and is why I achieved results that were beyond what most people were getting. Over 1.0 COP was always easy without counting mechanical work.
Doesn't make difference inside to outside but you can test. Otherwise, just change magnets.
Both books may be available before the conference at the end of June. Anyone interested in the SG technology definitely needs to come to the conference!
TheunisLast edited by Prinsloo; 12-10-2012, 10:57 AM.
Originally posted by forelle View PostHi Aaron,
This was a really important explanation in the update and needed.
A last question about the coilwounddirection(cant believe that nobody has seen this the hole years):
I have wound them cw so i have only to change the wires,but does it make a difference if the electronflow is from the outher side (-)to the core(+,like the left bottom picture) instead like JB makes the coil ccw = electronflow from the core to (-) to the outherside(+),both make a southpole,I guess nobody has tried this,exept JB,i think.
Second methode would be to simply turn the coil then you have it ccw,but in many cases the inner wires come out in front of the magnets which would be no problem if the gap is not to near.
Thank you very much.
P.s.when are the other books available?
Originally posted by sinergicus View Postthese books will be updated part of the The Complete Beginner's Handbook ,or separately as new books available after purchasing them?
Originally posted by Aaron Murakami View PostWind it like the top right one - that is what is shown in the book - that is NOT a mistake. With the positive on the wire coming out from the left side of the coil, you will get South at the top.
It will make everyone wonder what is going on since it has always been the opposite, but there is a reason that will be clarified in the updated book that should be released by the end of the week.
It also needs to be pointed out that it is irrelevant whether any of the leads are at the top or the bottom, the only relevance is where you put the positive. On the wire coming from behind the coil and to the right? That will make N at the top of the coil. Or, on the wire coming from behind the coil to the left, that will be S at the top of the coil.
They are inverse of each other in the way the machine runs and both work.
The N at top is the standard way and the S at the top will let the machine run different - again - clarification will be in the updated version at the end of the week as to what this is all about.
I just bought the book ....I understand in the near future will be new books :The Bedini SG, Book 2
respectively [The Bedini SG, Book 3...My question is:these books will be updated part of the
Thank you
