Hello all
This is a new circuit of a Voltage Triggered Capacitor Pulser with Schmitt Trigger that I have compiled. The idea is to use a schmitt Trigger, to let the cap charge to 24V then down to 17V or so, then back to 24V. This is a theoretical design at this stage.
Cap Pulser with Schmitt Trigger.pdf
Q1,R1,R2 and ZD1 offer no voltage regulation in any way. The purpose of this circuit is to let the cap (C1) charge up to 15V with nothing loading it. When the cap(C1), charges to 15V, Q1 gets turned on, and lets power flow to IC1, then C3 stores some power. VR1 provides an adjustable voltage to appear at pin2 of IC1. C2 is connected across VR1 so that any voltage spikes are actively filtered out by IC1. (very similar to the beta multiplier gyrator filter in Bedini's "Linear Amp Regulator")
R4,ZD2 and C4 provide a static voltage reference for the schmitt trigger and the comparator. VR2 sets the threshold voltage which the "schmitt trigger" triggers/turns on. When the "schmitt trigger" turns on this switch's the comparator on very fast. When the "Schmitt trigger" turns off, the comparator turns off very fast.
The comparator drives the mosfets "Q2,Q3,Q4 and Q5" on and off at a very sharp slew rate. VR1 should be adjusted so that the mosfets are driven hard at 15V or so.
The Schmitt Trigger has been shown as a block, because the internal circuit of this block needs further experimenting with.
Schmitt trigger http://en.wikipedia.org/wiki/Schmitt_trigger
enjoy
