in trying to increase the efficiency of my machine and reduce losses, in the switching circuit, i have found that putting a low-drop schottky diode in series with the base resistor instead of a reverse blocking diode (in parallel with the base emitter) I get better charging, lower input current, and the filament bulb is not as bright, the spikes to the output battery are larger on a scope and the drive transistors stay cool. currently it is working in energizer mode, i will let you know if it works with a rotor as well.
It does work with a standard diode 0.7v drop too.
