Originally posted by Deuis
- strength, spacing and size of magnets
- coil core material, diameter, shape and length
- outer spool diameter and length
- wire size and number of turns
- how much voltage vs amps do you desire on the output
- magnet to core gap
- the motoring strength of SSG is critical as well as the speed at which it wants to run.
please, anyone, add more that would truly be relevant to a coils output as a generator only.
- Is a coils output truly liniar in voltage and amps to the number of winds?
Here is more food for thought:
look at the "magnetic fields" string to start.
So now, if your desire is not to use the SSG as the prime mover, one still has to take into consideration all aspects of the motor being used to turn the wheel.
