  • John_Bedini
    my machine
    This is what you do not know, please do not ask where it came from just except it, all as i can say is only a few know. but this goes way back in time. as I said there are two schools of thought.
    John
  • Notsure
    I would like to give some food for thought, not trying to sell anything here. What if you reverse the general idea that light is a manifestation of the electric? That actually it's the other way around? That by saying energy can't be created or destroyed, your really saying light can't be created or destroyed? The power company uses magnetism to sell you electricity but your not paying for magnetism. They are selling you light and heat by way of resistance to magnetism. So I don't think you can create something that's already there, it's the resistance to it, long waves to short waves or whatever. I don't understand it either, just kind of a fuzzy logic point of view.
  • Ed_Morbus
    John Bedini
    Thanks for sharing.
  • BrentA929
    John B,
    Thanks for all that you have been sharing...
    Is it critical to get the inductor/coil(s) into resonance on your machines? Is resonance what makes the current draw so low? If so, is there a way to determine what the frequency needs to be on any given coil without a scope, signal generator or other expense device?
    Thanks, Brent
  • John_Bedini
    My Machine
    At All,
    Yes that is correct as you all seem to be grasping this. This is not an easy field to work in because it's like a starving artist in a way as you have no support and you must do things on your own. You will end up talking to yourself while you experiment on magnetic fields, and where does the energy come from? But look at it this way, if there is a second law of Thermal Dynamics the opposite must be true. Nature does not conform to that law as we see it. Nature moves everything as a negative energy zero force until you block it, for example the sun seems to be hot as we see it but what if it is not and it only seems hot because of the rays that strike the atmosphere. What if it is just a glowing ball of magnetism? What if the magnetic field is separated and the glowing force is neutral like the Bloch wall in a magnet. The next question is have we been taught to only see it one way and there is a second school of thought only known to the few and not the general public, I think so. Magnets are a very cold forces or they would not be magnets once they aligned there is no eddy currents to slow anything down or generate heat or the magnet would destroy itself, eddy currents only appear in a waste condition which is heat. Back EMF is another miss used term back EMF is not that spike that appears that burns your circuits out back EMF is always lower than the voltage put into the coil as it is the heat process (waste), just go think about it. That little spike is where all the magic is whether you want to believe it or not. The SSG is designed to have parallel circuits to take advantage of capturing all the spikes it can and add them together. The next issue is the current in the base of the transistors and to control it with the amount of current you apply to it. As you decrease that the machine will increase in speed to a point of self-oscillation at which point you have a radiant oscillator of which will run a one wire circuits using the plug circuits of which there are many as can be seen on the cover of my book Free Energy Generation. The energy from the Radiant circuits is a very different beast and has to be converted to be used and then you’re dealing with time charges so it may not work in a battery the same way however that can be converted too. So here is a picture of what that magnet looks like from my lab notes from the 80’s this is a little more complex than people think and you will be dealing in the quantum mechanics reality. More later…….
    John B
  • James_Somewhere_In_Idaho
    Hi guyzzemf
    So, looking at these illustrations, the first attachment showing the "low pressure gradients returning along the dielectric plane" are what John was trying to explain to me as having a spiralling four cloverleaf configuration, and the dielectric plane is a representation of the "Bloch wall" as per John's description? And, the rest of the illustrations show how the vortices react in space? Am I interpreting this correctly? Thank you for providing these illustrations.
  • guyzzemf
  • John_Bedini
    It's not easy at first then the light bulb turns on. it not an easy field to work in as you are all alone talking to yourself, you will get it and we are here to help.
    john
    Been reading your posts here a few times over seems to me I’ve read this before and did not pay as close attention to it as I am now. Some of this I have to admit is very difficult for me to grasp.
    I’ve been taking what you’re saying here in the context of the tuning the monopole using the Bipolar Switch. I’ve had a couple of hours this morning to pay closer attention to this than I have in the past. Using the Bipolar Switch, I am having very interesting results in terms of charging vs input. It’s going to take me a while to get it together.
    I’m applying everything I think you are talking about to the tuning of my bike wheel energizer and two 18awg coils using very little current, charge to cap, then dump to battery. There are some things you are talking about here that I have never applied to the Bipolar switch. Anyway, just want to let you know I’m working on it and hope I am going in the right direction…
    Kind Regards - Patrick
  • min2oly
    Hi Notsure
    I like that song...my son turned me on to groups like them. Carry-on
    Hi John
    Thank you for your explanation--it kind of opens up my understanding more. Now I must ponder on that a bit more to really let it sink in. (I kinda-sort-of have this work-shop in my mind where I visualize things working, and then I work on concepts before building anything. That way I have already worked things out well enough where my actual prototypes end up pretty good--well, at least from my own point of view).
    It is very important for me to really "get this" as I, too, feel time is of the essence in regard to the lights, literally" going off, and I do not take these things lightly. I mostly watch what others are doing, though, and then work on my own projects with what understanding that I have gleaned. However, I feel I must be more proactive and seek answers to my questions. And, while a lot of people might view this as a hobby (as you say) I do not. I view it as a necessity, and devote considerable time to this effort.
    I really appreciate all the help and expertise found here--people like Patrick, Tom, Nityesh, and others, and especially you, John, because we would all (most likely) be groping in the dark, without the sound direction you provide.
    After I fix (improve) the bobbins for my coil litzing contraption, and finish the solid state charger for my big batteries (hopefully by this weekend), I can then work on the other two smaller projects on my list (a small battery charger for my wife, and a system to run LEDs for growing food indoors) as well as this one (which might lend itself to the latter).
    Thank you--ALL
  • Notsure
    "Hints Allegations and Things Left Unsaid"
  • John_Bedini
    My Machine
    Jamesgray 3rd,
    Thanks for your comments yes I hope you have got the concept on the coil as what we all believe is the farthest from the truth. Actually the coil makes up a four spin clover leaf if you look close at the drawing you will see it as it is in the drawing. I did the drawing quick and I’m not that good at it on the drawing program. The coil in space is just sitting surrounded by charges but the potential is not coupled to anything two of the vectors must get into phase for power to flow. The Bloch wall in an electromagnet is not compressed but wide open, but when the SSG circuit turns on the Bloch wall moved to form a magnet compressing everything to center when the current is released everything couples and produces the high voltage spike that spike then is in the correct phase to flow through the diode to the secondary battery but no current , so as you add current it then damps the radiant wave as current is the counter EMF to the phi o dot wave so it would be the same thing as taking the paddle wheel out of the river. Current is the control factor so you want to keep it at a minimum with flux gates or the SG. The circuits are set to keep control of all this by the number of circuits in the machine the base resistor is the important part as it must be adjusted to limit the drive on the transistors. Now another important thing is to put the SSG in attraction instead of repulsion. When the machine is in attraction it is in re-gauging mode and then the devices will run cold to the touch as it does not push the magnetic fields, so the magnet is attracted into the coil for free. The idea is to pile this potential voltage on the ions in the battery as the charge accumulates on the ions they start to move but they are big and it takes time to move them, so some have reported that they have disconnected the machine and the battery continued to charge, and that would be correct because it also takes time to stop moving once they are charged with this potential. Hope this helps more.
    John B
    Hi John, et al
    I think I understand the "how a coil works" diagram. All the chaotic arrows depict the random (for better terms) vacuum energy surrounding everything, and the angular line on the coil depicts the Bloch wall, where the energy enters the space of the coil between pulses, and is compressed out during the pulse, much like a water pump (for others, one can find John describing it very well on the "Energy From The Vacuum" DVD series). I realize one would need to put a proper capacitor in-between the spike and the run battery (if one wished to recover that energy into the driving battery, that is).
    My main question here is regarding the capacitors that are parallel to the coils in the drawing that Brodie posted. I realize that one could perceive that set-up to be an LC oscillator circuit, and if it is set up that way (in the diagram, not the video) all that should be needed it some kind of a switch and feedback to get it to go. If that was not the intention of the capacitor(s), couldn't one use it that way (maybe with a trigger winding) to fire the transistor, instead of a reed or hall switch? And, one therefore could determine an appropriate resonant frequency for the motor? Or am I way off base here?
    It could be that a so-called, resonant frequency is not important here (as much as it might be in a solid state set-up). And therefore having an LC circuit oscillating and setting a frequency is really not the purpose of the capacitors in parallel, and maybe I am looking at that diagram all wrong, as you said it runs better with a commutator than it does with switches and a transistor, so please correct me if I am wrong before I go off on some undesirable tangent. Thank you.
    James, somewhere in Idaho
    Hi John
    Thank you, THANK YOU, for sharing that! It pretty much answered all my questions, and confirmed everything that I have researched in regard to your processes, as well as, what other things I have picked up along the way. I really appreciate what you are doing.
