I have been studying electronics since I was 12. In 1982 I started electronics research in the US Navy. I have not given up any research. All of the posts are very good sources of inspiration. I plan to continue this thread of research until it has merit and a good return for all the members to gain from. A monster becomes less scary once you shake it's hand and become it's friend.
4 foot Bedini SG
Dave,
the Tiny window Motor rick made is really an SG running both sides of the coil it uses 2 segments of the window rotor for each pulse. what really seperates the window motor from anything else really is the drive circuitry which in the full bipolar circuit allows the same "part" of the coil to use both the north face and the south face of the magnet in the same place. you get a drive pulse every 60 dgrees on a 6 sided rotor as the poles flip over the coil. I do understand the basic functions, but the geometry of the coil, its distance from the rotor, wire gauge and number of turns, and it being hall switched and the timing involved in that all play a factor in efficiency. I have seen one self run off a capacitor when speed and trigger width are perfect. only seen it once. DadHav had some pretty amazing rotors on the old forum, running on microwatts.... we need a rotor size, magnet width and a few other things.
Tom,
I remember John B. had a video of, if memory serves, it was a window motor were he was showing Rick and some others how the machine would run then John changed around a wire and the machine went into overunity and started to charge the primary battery. I think it showed scope shots as well... That video was on the net for a while but no longer. I have wanted to look at that scope shot for some time but no one seems to have it anymore. Do you have that vid?
Regarding the window motor if you are going for maximum efficiency that will take an extreme amount of work, time and dedication to maximize. You could have a life time of work...on your hands.
I will post some video soon and try to explain the configuration the brushless motor I described above eariler. I will try and include some theory on how I think it is working with the SG circuitry and how the SG can or could possibly use the full bipolar circuit. I will also touch on the window motor, in the hopes of learning more about it as well.
Good news, the post office sent out a lady to hand deliver my order from TeslaGenX. Bad news, the contents of the parts were not correct.
instead of 10 4.7Kw resistors I got 5.
Zero neon bulbs.
Two(2) packages of ring terminals.
The rest of the parts are yet to be evaluated due to inaccurate labeling, i.e., circuit board standoffs, heatsink standoff and transitor screws, mini binding posts.
I believe the effort was genuine, but whoever packed my order was either very tired or in need of new glasses.
Please send me the parts I ordered at the P.O. Box address I provided in the PM. Thank you.I listen to Alex Jones and I fight against the New World Order. Are you a flouride head? Великий Белый Волшебник
Are you talking about the video of John and Rick where John was showing what he thought the guy who replicated the window motor running off a capacitor might have done to make that work? if anyone posts that please post a link...Originally posted by Tom C View PostDave,
no I do not have that vid, wish I did!! the ferris wheel uses a Highly modified bedini cole switch so we know it can be done, but how is another thing.
thanks,
Luther
why_me (aka Great White Wizard),Originally posted by why_me View PostGood news, the post office sent out a lady to hand deliver my order from TeslaGenX. Bad news, the contents of the parts were not correct.
Zero neon bulbs.
That's great that you received your kit! Sorry to hear that it was not received as expected.
We'd be more than happy to send the parts that were missing from the kit, however to help us resolve this issue quickly could you please thoroughly check all of the items that were shipped so we can send the missing components in one shipment?
The kit includes the following:
1 x Circuit Board (PCB)
8 x matched MJL21194 transistors
8 x transistor thermal pads
2 x aluminum heat sinks with screws
16 x 1N4007
8 x 470 ohm 1W resistors
1 x 12 ohm 10W resistor
8 x Neon bulbs
8 x 4.7K ohm 1/4W resistors
Screw terminal blocks to connect coil wires and batteries
Extensive pictorial assembly instructions with parts recommendations and tuning instructions (electronic)
Complete circuit schematic (electronic)
Thanks again for your feedback!
Luther,
You do remember that video? I am talking about the video where Rick says " here we go" and everyone watches the primary battery rise on the DMM, they also show a couple of scope shots of what is going on. That is after John changes a wire around.
DaveLast edited by Dave Wing; 12-23-2013, 09:05 PM.
I hope that helps.Originally posted by why_me View PostGood news, the post office sent out a lady to hand deliver my order from TeslaGenX. Bad news, the contents of the parts were not correct.
Zero neon bulbs.
Well, an accurate counting of nuts, bolts, washers, stand off insulators, that kind of stuff. Just so I can be aware of any future difficulties while assembling the circuits. Sorry for the time lag, I had guests.I listen to Alex Jones and I fight against the New World Order. Are you a flouride head? Великий Белый Волшебник
your components are boxed and will be out tomorrow A.M. each individual package has the item and quantity on it. there are EXTRA of every component in case you destroy one during assembly, or drop a nut onto the floor and cannot be found. I cannot forsee you having any trouble..... with your experience in the military this circuit should be a snap, included with your order was the pictorial assembly instruction set and the schematic. the circuit board is silk screened and components are labeled in normal electronics parlance.
hard to understand...
what is the last sentence of jb conclusion ?
what was the myth?
any undertitles available?
