Pertronix claims you need a 3.0 ohm coil for 4 cylinders or less. Place I bought it from said the same thing but there not using it for what we’re doing either. I also have a Pertronix Ignitor I magnetic pickup sensor also. I ran the coil and sensor and it’s working fine. Next step is to hook up msd street fire and diode up. Again my main concern would be either to much resistance and not achieving plasma or burning something up.
I use a MSD 8222 High Vibration Blaster Coil with mine and it works great! It has only .7 ohms resistance. Here's the link. https://www.jegs.com/i/MSD-Ignition/121/8222/10002/-1
Leave a comment:
coil
Can you post a link to your coin on Pertronix's own website?Originally posted by RB176 View PostWill a coil with a 3.0 ohm internal ballast work for plasma or does it have to much resistance? I am using a Pertronix Flame Thrower1 with Granatelli wires.
Leave a comment:
Plan B is what needs to be worked on, because it's getting tougher to find cars with carburetors and Distributors.You're on the right path with realizing each of your Caddy's coil packs are a primary AND secondary with terminals to two cylinders. The first trick is to determine how to apply the diode, the second is to shorten that energy delivery to the primary (duty cycle/energy under the curve...) without burning it out.Originally posted by jodyaustin View PostAaron or any other forum membersA couple of questions:I came across a sparkplug by Pulstar (Pulstar :: The world's best, most powerful sparkplug.) that has a capacitor built into the plug. Could this be used in addition to a capacitor on the coil circuit....ie...CDI circuit? My caddy has two Ignition Coil Packs (with separate coils for each plug)....I don't think I will be able to use your Plasma circuit because of this, and am wondering if these capacitor spark plugs would still be usable to increase the strength of the spark (similar to your approach in Chapt 3 of your book....just has capacitor built into plug).Also, my perception is that the plasma effect cannot be obtained with resistor plugs....am I correct that if resistor plugs and plug wires are removed, it will screw up the radio/electronics that are emf sensitive?Because my caddy uses coil packs and Street Fire said they don't make a CDI unit for my car, I am doubtful as to whether plasma effect can be achieved using your methods. Would I be gaining ground if I can figure out a way to put a large capacitor and diode string in the circuit for each coil in the coil pack (in place of a CDI unit)? If so, what size capacitor would be recommended? If I used this approach, would the Pulstar capacitor spark plugs coupled with the in circuit capacitor increase the spark/plasma at the plug tip, or would they interfere with each other? Any thoughts or suggestions if this "plan B" approach is used on newer vehicles?Jody
Leave a comment:
Close: MAP sensor adjustment. EFIE is what adjusts the signal from o2 sensors back into normal range after better combustion makes for higher oxygen content in exhaust, and would've helped with mileage.Truthfully, you need both for a proper, full optimization, because an ECU is programmed to work very hard (and given ridiculous tools to aid itself) to hit 14.7:1Originally posted by krisskool View PostHi,I have a subaru too (waste spark) and I have tried the sparkamp x40 High Performance Ignition Systems > Ignition Kitsbut at this time I didn't retarded ignition timing so the change was not as it could have beenI am curious about the method for retarding ignition timing, maybe efie (cts, maf, o2, ???)
Leave a comment:
Those diodes are good - used to use the CL2 series diodes a lot in the past - even back when they were $25 a piece! I'd search ebay for 3amp hv diodes to see more options.Originally posted by Alstrup View Posthttp://www.setecelectron.com/product...p?selectId=649 Do you guys think that will be worth a try or am I on my way out on a tangent?
Best regards
Torben
Leave a comment:
Best regards
Torben
Leave a comment:
Can't help with kapton wire, but if you scroll to the bottom of the link for the description, you'll likely get a bit closer to answers:https://www.aircraftspruce.com/catal...dlwire.phpwith a mil-spec code, you should be able to find wire that meets or possibly exceeds your requirements, for less than aviation prices. ($500 is what is said to be found in the seat cushions of small aircraft, and a cappuccino machine for a Gulfstream is $10 grand)Originally posted by Aaron Murakami View PostBeen looking for Kapton wire myself for another projects, specifically 23 AWG coated with Kapton CR (corona resistant). Double build is preferrable over single build, but triple or quadruple is even better if it doesn't cost a fortune. Need a 10 # roll if you or anyone else knows where to get any. All the wire manufacturers and major distributors are really flaky - never respond to quote requests.
Leave a comment:
Been looking for Kapton wire myself for another projects, specifically 23 AWG coated with Kapton CR (corona resistant). Double build is preferrable over single build, but triple or quadruple is even better if it doesn't cost a fortune. Need a 10 # roll if you or anyone else knows where to get any.Originally posted by heysoundude View Postkapton, perhaps? it's used for wiring harnesses in aviation applications.
Leave a comment:
I now have this plasma ignition unit installed on my 3550 watt gen set. I don't need the 555 timer for this as I am triggering with a hall switch next to the original flywheel magnet. Here's some photos of the set up. The last photo is a close up of the surface gap plug I'm using.Originally posted by Gary Hammond View PostHi All,
I just finished a replication of Aaron's 555 timer circuit driving a street-fire MSD module thru a MSD Blaster coil. Here's a video of it installed over a fogger unit while I was demonstrating it to my son and grandson (and exposing them to dangerous radiation - LOL).
The video starts out with a surface gap plug installed without fog and then with fog. Next comes a regular plug with conventional gap. It runs both with and without fog added. Then a little propane gas is added (both with the fog and without the fog), and finally I show my plasma lighter.
We all lived thru the experiment and my son Bob took the video.
Leave a comment:
kapton, perhaps? it's used for wiring harnesses in aviation applications.Originally posted by Faraday88 View PostAaron, During my tenure at Honeywell I worked for an 'Ignitor' Project, and we custom made these HEI Spark coil, it was a CDI type of Ignition system and we had these miniature coils hand made with heavy insulation using a material (don't recollect the name) like teflon. including the wire jacket made of the same material.Rgds, Faraday88.
Leave a comment:
Hi RB176,
On my set up the diode (+) is toward the plug and the diode (-) is toward the coil primary that is marked (+) from the MSD box. It all depends on which polarity your coil is.Originally posted by RB176 View PostI’ll be using the PRHVP2A-20 Single Phase High Voltage Rectifier Diode so with these diodes, so I’ll be putting the cathode side towards the plug. Is that correct? Coil + to —>|— towards plug?
If it doesn't work one way, just swap the leads on the diode. It isn't going to hurt anything if it's backwards. It just won't fire the plug at all if it's wrong. It just shorts out the plug gap if it's backwards.
Leave a comment:
Leave a comment:
Leave a comment:
