So, the Iron-Air batteries typically are made as Flow-cells, but is it possible to build an Iron-Air solid state gel electrolyte? How would one gel the electrolyte to allow for fast enough ion transportation... hmmmm interesting. Would a basic PVA-KOH gel electrolyte work? Maybe fumed silica and sodium polyacrylate.... gaaaah. I want to build my own battery system, small 24V unit. Ni-Fe chemistries are easier, but heavier and more expensive. Iron-Air has more energy density, lower nominal voltage of 1.28V..... alas, will just have to experiment and try ot both as little test cells i think. Ideally i want to build the Proton-Urea battery, but who has money for Iridium XD wonder if it would work with Ni and Co Oxides instead .... hmmmmmmmmm even more.
What do you think?
What do you think?
