building "engine" for hyper-luminal space travel + a device for entangled bridges
  • building "engine" for hyper-luminal space travel + a device for entangled bridges
    These pictures are not ideal, i know, i am working on better copies. These were done quickly to transpose the general idea. Which is an actual means of building a "engine" for hyper-luminal space travel, and a device for the creation of entangled (stabilized) einstein-rosen bridges. If entangled photons where used as the triggering source to the G-beam, and two entangled photons of opposite spins where used in two separate devices, the field effects generated would be entangled together, oppositely charged. Assuming enough energy was input to generate such a phenomena in space.
Name:	my idea - 1.jpg
    This image is the basic Podkletnov G-beam experimental set-up. Quartz glass is closed, not open.
Name:	my idea - 2.jpg
    This is a terrible depiction of a "special magnetron". It's a typical microwave magnetron, however the Magnets are replaced by wave guide shaped YBCO composite material rings. These are designed to accelerate the magnetic component of the generated EM wave away from the magnetron itself, at high velocities. Acting sort of as an Electromagnetic repulsion system, designed to the wave being emitted by the physical cavity resonator.
Name:	my idea - 3.jpg
    This is an advanced Podkletnov G-beam set-up where the YBCO electrode has an aperture for a highly concentrated EM-beam through, acting as the triggering mechanism between the electrode and target. This is very similar to LASER excited Cathode Ray tubes. However the EM radiation here comes from a very special type of Magnetron set-up.
Name:	my idea - 4.jpg
ID:	51458Can anyone reading this help me by creating digital schematics and/or 3d images?
