I'd rather just run off my own batteries and use the grid as a backup. The problem with grid-tie (and part of the reason the Australian government has cut back on rebates) is because there is currently no infrastructure for large scale "mom & pop" solar/wind grid-tie setups.
I believe Perth in Australia sometimes has issues where there are too many home solar grid-tie systems for the grid to handle. The reason being is that your home grid-tie system puts mains voltage back into the grid (e.g. 240v in Australia). This is great for everyone on your local 240v sub-station because what you are putting into the grid your neighbour is probably using.
But what happens if people on your local 240v sub-station are putting in more power than what is being used? Guess what? The power company has to burn it off somehow because there is nowhere to store it, no way to patch it to another sub-station and no way of transforming it to a higher voltage for wider distribution.
This is typically an issue in new housing estates, where mom & pop go to out to work all day and there is no one around to use up all the power that is being shoved back into the grid from all the solar grid-tie setups.
So why not charge up your batteries during the day and use your own power at night when you get home from work?
But what about the feed-in tariff that pays you more per kWh than if I have to buy it you say? Well, that's a scam. Most power companies around here have locked in the feed-in tariff rate for 15 years, but have they locked in the buy-back tariff? Heck no! In a few years the buy-back tariff is going to exceed the feed-in tariff and the crappy panels they are putting on your roof are going to generate less energy every year, so in a few years you'll be back to where you started.
Bedini method is the first step towards what can be called as a TEMPORAL BATTERY, if we figure out a way to Engineer the Aether or the vacuum to create a SPATIAL BATTERY or a TEMPORAL ARENA with it, we shall figure out the ultimate 'Storage' of ENERGY and 'Channeling' of POWER!!!! how is it like acheiving this? are we in the relam of making the Homogenous Space (one) as a discreate node of realization or of self-evoked experience within each of us induviduals.. just a thought! or put it different is the Bedini-Movement already doing this.....????? Para-philosophy at this point perhaps!
Rgds
Rgds
