Originally posted by RS_
Bedini 1984 Generator
ps, I would highly recommend pulsing this with the arduino like bob demonstrates pulsing a coil... arduino gives you I higher level of control in the microseconds and is very straight forward. with this setup you will see the pre-spike :-)Originally posted by DMANN View PostHey. I want to explore the 555 timer/relay circuit. I am searching for the relay component and found this one: https://www.walmart.com/ip/JQX-62F-D...&wl13=&veh=sem
I also have this schematic: [ATTACH=CONFIG]6537[/ATTACH][ATTACH=CONFIG]6537[/ATTACH]
Am I on the right track? Is there a better schematic/components?
Doug
Yes..Thanks. The commutator effect is what I am looking to use this for. I have that relay on order so I will give it a go when it comes in.Originally posted by min2oly View PostIf using this, also replace coil with the relay component so you can get the hard on hard off commutator effect which I believe is the reason for the build in the first place :-)
I need to get on board with the Arduino.
