Electrical Energy + Hydrogen Patents Claims
A US Patent issued costs thousands of dollars by the applicant. It contains data and electrical schematic of GENERALIZATION only.The whole and accurate wiring lines hook ups are never there, except for the Horvath Patent- which has 1 1/2 pages proofreading errors only. The claims list involved never states over unity or free energy. If highly interested, you have to do research on the applicants involved and see their manuscript and related technical data, FOR THEIR CLAIMS, not put in the original Patent application.There is usually some data available.
As for example the Jackson Water Burner was Patent about high pressure 90lbs, high temperature 1500 degrees steam through tiny oil nozzle to ambient air that transforms to hydrogen torch in highly insulated oil furnace chamber. What wasn't noted in Patent, was that magnetic field poles must be involved, pulling on the highly agitated, volatile,water molecules electron orbitals to change the angle in degrees on H and H to the Oxygen atom . (more vulnerable to separation.) I read their manuscript. The US soldiers from 1950, furnace running on water line 100%, after fuel oil starting, received only stated in Patent as 50% allowed increase in efficiency.
Same thing with the Hydrostar Patent by Chambers. The included schematic does NOT SHOW wiring of the available high voltage back EMF from wire inductor coil, to be applied to the electrode SS pipes in water cell. Patent reference was only 25% increase in efficiency allowed. The ONLY ALLOWED build parts manual ended with same only. He had earlier worked for Meyer of Water Fuel Cell in Ohio, and was fully aware of Meyer's work of over unity Hydrogen generator called Voltrolysis. Meyer's Patents time have ran out and are in public domain. Others are attempting to build his cell.Last edited by russwr; 01-31-2025, 04:07 PM.Tags: None
