ONE MORE THING - TESLA COIL WON`T WORK , because it is a resonant transformer and doesn`t have enough copper to produce the big PLASMA FIELD NEEDED TO EXTRACT THE ENERGY FORM THE VACUUM TO CREATE THE WATTS.
Well , it might work but it has to be real huge and I think it is inappropriate to use.
To create 5-20 kw/h you need at least 10-20 kg. of copper to make an old style induction coil producing 20 000 volts, or easier done is to make with the same amount of copper 10 induction coils producing 2 000 volts each, pulsed from one source, with 10 spark gaps after to transform the current to AC and if the voltage is 2000 volts it can be used to power the motor directly without transformation , with only powerfull controls for the speed.
For me this is the most logical solution.
Petio.
Petio.
It is about Nikola Tesla's electric car he build 100 years ago. You can't even take a picture of it and trying to buy it will be even harder
