Greetings from Lithuania. I need advice of my system.
The coil I've wounded in picture
I use npn 2n3055 transistor, 3A diode on output, base-emiter 1A diode, ~5k variable resistor. All oscilosolographs measurements on emiter-collector. Im charging 7Ah batteries from 7Ah primary battery too. Coil parameters is 34m of three wires. Two (both) on power wires and third on base. Base wire ~18 omhs, powerwires ~9 omhs.
This is the first point of my charge primary current:
Current is 0,22A ant oscilograms are straight square.
This is the second point of my charge current:
Current is 0,42A and there some soft shape of straight square.
This is the third point of my charge current:
Current is 0,44A and there line down.
Coud You help me understand what I see on oscilograms? Whitch one of charging points are better?
Robertas
