The Ultimate Cap Dump
  • Sorry to but in guys,,, Aln you need to clear space in your private message box. I tried to reply to you but it was rejected until you make space....
    • Sorry Bob, its good now. Ed I will work on that soon. Al
      • Ok thanks Aln
        • Hope this is big enough. When I printed it from "do it yourself circuits," it was a little fuzzy. So as I mentioned earlier, watch Patricks video with this in your hand, it will make sense. Aln
Name:	big pic of comparitor.jpg
          • Thanks Aln and is this goodClick image for larger version
Name:	Schematic for Pats Comparitor [1].JPG
            • Ed,
              You are close. I see I made a mistake too when I was looking at it. I use a 100K pot on the top instead of 10k. For the dumping cap I would have 10,000 uf as a minimum, depending on the size of your machine. For the cap across the mega ohm pot I have a 10 uf not a 10 nf. And last Connect the ssg negative to the emitter, top left of SSR and bottom left of SSR. You have no "dot" at that junction in your schematic. Fix those, post again and I can take mine down as yours will be better Aln
              • Thanks Aln is this betterClick image for larger version
                • Looks Good Ed. I think I had a 35v 220uf cap on the one where you have 100uf too, not that it matters much there. The voltage is low. Good work and good luck, look forward to your build. Aln
                  P.S. Don't go too cheap on the SSR or you will have to buy another after you push the cap dump to do some hard work.
                  • Thanks I have no SSR
                    will you tell me what SSR you use
                    • Read post #264, pat uses Douglas Randall K08A. Mine is only rated for 40v at 12A on top and 3-32v on bottom to trigger switch, but it is working good so far. I had a Chinese one rated for 110v at 25A on top, 3-32v on bottom and I killed it. Remember DC/DC. I have 2 AC/DC ones that work about the same as my dead DC/DC one .
                      • Is this goodClick image for larger version
Name:	CLion SSR Dc to Dc.JPG
                        • Looks like it will work, where is it made? ZHEJIANG looks Chinese to me. Not all Chinese is bad, I just haven't found the good stuff yet . It looks better than the one I killed. And the one I bought was only $10 on amazon. I bought the Douglas Randall on ebay used for $15. Aln
                          • a bit off topic but neat .but it reminds me of Edward Leedskalnin Perpetual Motion magnetic currents-
                            PMH
                            WICO EK MAGNETO
                            • Hey all,
                              it took me long enough to remember...
Name:	Cool Joule MCD.jpg
                              add as many Mosfets as you need so they share the load and share the trigger/led to the gate. Play with resistances/caps that work for your coil.
                              cheers,
                              PS please let me know if you think there might be something backwards etc...
                              • Nice - check it out on a CRT from about the 8 minute mark.
                                PMH
                                WICO EK MAGNETO
                                https://www.youtube.com/watch?featur...&v=UsYlBV8atFY
